tps sensor helppppp
Old Mar 20, 2015 | 05:08 AM
turboback1243's Avatar
tps sensor helppppp
Installed new tps and car won't idle. Tps is set with evo scan at 13.333% with engine off key on. What should it be set at with engine off? Thre p0122 for tps low voltage please help set this up
Old Mar 20, 2015 | 05:09 AM
I don't get how to test tps with multimeter I need detailed help,on that if someone can assist it would be greatly appreciated
Old Mar 20, 2015 | 05:44 AM
firmk20's Avatar
check the ground, make sure is tight and all other wiring. make sure its mount correctly they are a pain in the neck. had that problem with my kseries honda
Old Mar 20, 2015 | 06:13 AM
It's mounted corectly I just don't know,how to set it correctly. And I have it at 13.333% with evo scan,motor off and,key on but won't idle
Old Mar 20, 2015 | 07:21 AM
evo8426's Avatar
What all was changed? That is the correct %
Old Mar 20, 2015 | 09:45 AM
You are supposed to set it to that % with the engine off right?
Old Mar 20, 2015 | 11:36 AM
I may actually have it on incorrectly. Are you supposed to put in on and rotate it up?
Old Mar 21, 2015 | 06:39 AM
kamote2000's Avatar
Did you set the biss screw using sas mode?
Old Mar 21, 2015 | 06:51 AM
evo8426's Avatar
No need to touch the biss screw if only replacing the tps.
Old Mar 21, 2015 | 09:14 AM
This is what I did.
With car off key on
I lined up the tab on the tb and twisted the tps so I could put the 7mm bolts in.
I stuck a pin in the tps output and put my multimeter on the pin. I adjusted it until it said .65 volts. When full throttle goes to 4.99v.
In evo scan with engine of that's 12.7%
Corectly done or wrong?
Old Mar 21, 2015 | 09:21 AM
Anyone have evoscan that can log their tps % with the engine off key??????
Old Mar 21, 2015 | 09:56 AM
evo8426's Avatar
12.9% is what mine reads
Old Mar 21, 2015 | 10:17 AM
Thanks mine is 12.7 engine off key on. Or .65v. I have a map in there that most likely isn't good because I have a fully built motor now fp black set up bigger cams everything is different I just wanted to make sure my tps is correct just waiting for base map from,Cbrd. Thanks for your help man I really appreciate it. Hopfully it idles when I get that map! Should.
Old Mar 21, 2015 | 10:49 AM
firmk20's Avatar
worst case scenario your tuner should be able to help.
Old Mar 21, 2015 | 12:15 PM
egis's Avatar
