SRS Error Code
Old Mar 28, 2015 | 02:09 PM
WhiteHat's Avatar
SRS Error Code
Hello, I was just wondering if any one with the SRS error code 22 "DRVR A/B SQ 2", resolved the issue by replacing their Clockspring.
I have seen threads discussing how to replace it and others about suggesting replacing the Clockspring but I could not find a follow up confirming that they actually replaced it to resolve the issue.
Just thought I'd ask before I buy one.
Thanks in advance!
Old Apr 21, 2015 | 10:23 AM
spitefire1's Avatar
is their anyway to disable the srs light? i have the same problem!!
Old Apr 21, 2015 | 03:03 PM
superbovine's Avatar
Take a 2.5-3 ohm (not k-ohm) resistor and push it into the connector in place of the air bag and see if the light clears. If it does, the air bag is bad. If it does not, move the resistor to the connector going into the clockspring and see if the light clears. If it does, the clockspring is bad. If it does not, there is either a wiring problem between the clock and the ecu or the ecu is bad.
Its usually the bag, followed by the clock.
Don't drive around with the resistor in there like that though. Only use it for testing.
Old Jun 6, 2016 | 07:07 PM
WhiteHat's Avatar
I know this is an older post but I thought I'd follow up on my question and confirm it for anyone else having this problem.
I finally got around to replacing my clockspring and it resolved the SRS error code 22 "DRVR A/B SQ 2".
Cheers
otbEVO
Jul 6, 2009 11:36 PM
MREvOTard
Apr 14, 2007 12:32 PM
savageevo
Dec 27, 2004 01:14 PM
