E8 factory fuel lines - limits?
Old May 24, 2016 | 10:45 AM
Kevin Troy's Avatar
Hi Guys,
Has any one info on what the limits are for the factory fuel feed lines are for evo 8?
I found out that they are 5/16" (7,9mm). How much max bhp can be run before putting larger lines?
Thanks for info
Old May 24, 2016 | 01:03 PM
Your question is in regards to fuel flow & not fuel line construction? Correct?
What type of fuel pump are you or plan or running. Pwr levels below 600whp, I doubt any fuel line consideration is needed. I can see a fuel rail change at those high WHP no.s
Heres a good thread discussing the topic
https://www.evolutionm.net/forums/ev...ock-lines.html
Old May 24, 2016 | 11:50 PM
Kevin Troy's Avatar
Yes, I plan to run the walbro 400 or aeromotive 340 lph (with hardwire) for my 500whp build. I believe it should be enough.
therefore my question. I assume I do not need to run larger fuel lines. Fuelrail is Magnus, ID1000 etc..
thanks for the link
Old Jun 3, 2016 | 04:08 PM
JRally's Avatar
thanks for the link
The stock line is basically the size of a -6an line. You're fine with that for quite a bit of power. Buschur is running their double pumpers to that hardline and has plenty of fuel for 700whp.
Old Jun 7, 2016 | 10:18 AM
Kevin Troy's Avatar
Thanks for your reply
RallySport9
Feb 20, 2016 11:24 PM
anthonyrb98
31
Oct 31, 2012 02:34 PM
Evo4u2envY
For Sale - Part Outs
Apr 30, 2010 07:21 PM
dbsears
40
Mar 8, 2008 06:35 AM
tuning g
Mar 9, 2007 04:00 AM
