Evo 8 sometimes tried to stall when stop
Old Mar 29, 2015 | 11:22 PM
coreymelton's Avatar
So when Im cruising my a/f is from 14-15. Drives fine. Then when I come to a stop it acts like it wants to stall and starts to idle rough with a/f sunk way lean. Ove 16. And will go back up to 15. It doesn't always do it. When I start it cold it will do the same rich idle. And leans out. I'm not sure where to start. Im going to do a boost leak test and go from there. Just would like some input. Maybe leak in one of injectors? Thank you
2003 Evo 8 105,000 miles tuned to 19psi
Old May 14, 2015 | 03:06 PM
JCevo805's Avatar
i had the same probably 10 miles later bye bye piston
Old May 15, 2015 | 07:18 AM
Ev0ikon's Avatar
Don't come back until this is done!
Old May 15, 2015 | 09:26 AM
llDemonll's Avatar
Do you have a blow-off valve that doesn't recirculate? That will cause this symptom as well
Old May 15, 2015 | 05:35 PM
robbyredneck's Avatar
i thought they all did this
Old May 16, 2015 | 05:41 AM
Well I did my boost leak test and my shaft seals on my throttle body are leaking and my BISS screw was broken in the hole!! So I ended up buying the Mil.spec 65mm ported TB and the problem is gone! I do have an Evo 9 bov the is recirculating
sgambino92
May 27, 2018 07:30 PM
moyassine
Jan 19, 2016 01:13 PM
TheBigLubinsky
Aug 14, 2010 10:31 AM
