Idle drops very low after revving the car.
Old Apr 26, 2015 | 09:29 AM
Evo47's Avatar
Has anyone had this problem? My Evo is warmed up and at operating temperature. The idle is good all the time. But right after i rev it to 4k rpm's+ and let off the throttle, the idle drops below 500rpms. At that point the car sputters/shakes and takes 3-5 seconds to regain its regular idle rpm. I'd say 1 out of 10 times the car doesn't regain regular idle and just dies because idle drops too low. Any idea what the problem could be?
Old Apr 26, 2015 | 09:40 AM
Bob-o's Avatar
Sounds like your MAF sensor is trying to find idle. Check to see if it's dirty/theres a leak?
Old Apr 26, 2015 | 09:49 AM
Bhsj13's Avatar
boost/vac leak maybe. i used to have a coming to stop problem with idle where it will drop low and sometimes stall, sometimes catch. then, i changed out my stock 9 bov to my turbo xs no diaphragm bov and it hasn't happened since. people kept telling me it was the tune but why isn't it happening with the new bov. anyway, back on subject; try cleaning the maf and do a boost leak test first.
Old Apr 26, 2015 | 10:03 AM
Bob-o's Avatar
Forgot to ask. Did you do anything you remember to instigate this to start happening? Or did it all occur all of a sudden for no reason?
Old Apr 26, 2015 | 01:05 PM
Evo47's Avatar
I removed all the hoses/sensors/screws attached to the top of the intake manifold to clean/paint it without having to remove it. I also removed the uicp to clean it and paint it as well. Was tidying up the engine bay. Should i use regular maf cleaner to clean it up?
And there's no boost leak im sure. If there was wouldn't the idle always be rough?
I don't know when this started happening though, never bothered revving the car before, just decided to show off to a friend after it was clean, with me getting a bit embarrassed after doing it haha.
Old Apr 27, 2015 | 07:25 AM
Bob-o's Avatar
Double check to make sure none of the hoses have any cracks in them. You never know. Also double check the couplers on the UICP; maybe one of them slipped off a little
Regular maf cleaner will suffice. Report back with what ya find!
Old Apr 27, 2015 | 08:01 AM
Ev0ikon's Avatar
Did you really fill up the system to your boost target level and waited a few seconds? It's the ONLY way to be sure.
Old May 4, 2015 | 08:53 PM
tommyooooooh's Avatar
Had a similar issue with mine.
I ended up having leaking throttle body seals and a loose coupler on an intercooler pipe.
Fixing the leaks and cleaning the maf fixed my idle drop issues.
Evo47
Jan 3, 2017 06:43 AM
Delux247
10
Nov 28, 2012 09:28 AM
Srt-4 Turbo 7
10
Dec 21, 2006 02:28 PM
