how much boost can i run on a stock evo 8
Do you have any mods at all? Or is it 100% bone stock? Every car takes mods/tuning differently. Tell your tuner you want a conservative tune to be on the safe side. Or tell him to keep raising boost until you have knock/detonation then back it off. I would consider that a maxed out setup. I predict 23-25psi assuming 93oct is what your running.
My stock 03 turbo once spiked 34 PSI. It's got Methanol so I supposed that saved it. It ran daily spike to 30 PSI.
Just make sure the ignition timing is not too aggressive and cool the charged air proper (Massive IC and Chemical).
That's def too high for my liking on pump I'm thinking 25 would be my max.
from what i know and the tuners/turbo builders i've talked to, i wouldn't go above 25-27psi on a stock turbo if you want it to last long.
yes, you can do more, but you are seriously shortening the life of the turbo. and yes: people will swear it's safe. that's your call, though. 24-25psi seems safe on 91, 25-27 on E85.
if you bought your car used, it was probably modded and is now bypassing the OEM boost solenoid in some way. if you have it, you can hook it back up (assuming the ECU has been flashed back to stock). if not, you can add a manual boost controller. that should enable you to run more boost. assuming it holds 12psi throughout the RPM range, it's probably not a boost leak.
if you run more boost, you will be getting tuned. in that case, using a 3-port boost solenoid will enable your tuner to use the ECU to control boost pressure.
either way, you have a few options.
I'm running a stock 8 turbo right now on E85 and have found that anything over 28 psi actually causes a drop in power. The 8 turbo just can't push any more than that efficiently. Anything over 27-28 and your basically just blowing hot air. That's also peak boost for me. I taper to about 22 at 7k. Again... any more than that and the car starts to lose power.
