Need help
Old Jul 19, 2015 | 09:43 AM
Evo9Jay's Avatar
Need help
Hello everyone!
Every time I turn my Evo on it wants to turn off. If I stop too quickly it will turn off as well. I was told it is a throttle body problem, I'm hoping someone has some information about this.
Thanks a lot
Jay
Old Jul 21, 2015 | 04:40 AM
Mschalk35's Avatar
do you have any more information regarding this issue? Do you have an AFR gauge ?Could be something simple like a boost leak.
Old Jul 21, 2015 | 10:35 AM
Evo9Jay's Avatar
I don't have an AFR Gauge, my friend was driving the car and he rev'd till it the rpm maxed out and he heard a pop. After that when the car is cold and I want to turn it on, it will turn off if I don't keep the idle at 3. When I'm at a traffic light the idle goes up and down and if I turn the AC on it will turn off more often. Thats basically what happened lol
Old Jul 21, 2015 | 02:44 PM
Ev0ikon's Avatar
I bet lunch money on a busted coupler. Boost leak test. Learn it. And Live it if you want to keep driving your Evo!
Old Jul 30, 2015 | 12:04 AM
Evo9Jay's Avatar
I checked the coupler it was fine. I changed the MAP sensor and the car idles fine most of the time. I still have the problem when I slow down and clutch and then the car turns off. The idle is still going up and down but not as much since I changed the MAP sensor. The idle goes from 900rpm - 1300rpm.
At times its fine the idle sits at 1100 and the car sounds fine. It has its moments I guess.
Earthen
23
Jul 22, 2010 06:43 AM
drc
Jul 19, 2005 08:33 PM
Kwman
21
Jul 14, 2005 07:34 AM
army685
Apr 26, 2005 05:43 AM
TeamNeXusOz
West Region
Jun 9, 2004 08:56 AM
