AC compressor turning on and off
Old Aug 29, 2015 | 10:57 AM
pistons4550's Avatar
My AC recently stopped working and it turned out that the discharge hose had a hole in it from rubbing against some of the IC piping. Got a new one, replaced it two days ago and ac worked fine. Yesterday it stopped working momentarily then resumed normal function. Again today it stopped working but then worked again until finally settling into where the compressor turns on and off every 5 seconds. So I keep getting warm and cool air. No leaks that I can see. Mechanic who changed the discharge hose said the old one had some water which worried him. Does anyone have any ideas/advice on what to do. Really friggin hot in Florida right now!
Old Aug 29, 2015 | 02:20 PM
egis's Avatar
Make sure the system is full.when sensor don't see enough pressure AC goes on/off.could be a leak somewhere. You can't see the leak some shops have a device to locate the leak.
Old Aug 29, 2015 | 10:53 PM
Wingostype420's Avatar
Deal with this on a daily, could be low or to much refrigerant, also a bad orifice will cause this. Take it to a shop and have them put dye in and see if you have a leak
Old Aug 30, 2015 | 04:42 PM
Well i just got my leak fixed so i doubt that can be it, but I guess they didnt put enough or too much refrigerant. What do you mean by bad orifice?
Old Aug 30, 2015 | 05:30 PM
ToLate24's Avatar
If your orifice tube is plugged it won't let the system flow freely and in that case will build pressure. When it hits a certain high pressure the high pressure safety switch will kick the compressor off.
Old Aug 30, 2015 | 05:46 PM
barneyb's Avatar
Any time the system is open it is considered wet. If open for more than a few minutes you should consider a new dryer. Pulling vacuum, which is done after replacing a hose and before inserting refrigerant removes the rest of the water (and air).
How long the compressor stays running is determined by the heat load. If a cooler day and a cooled car, five seconds could be normal. Warm air probably means the compressor clutch is shot.
RalliAaron
Jun 28, 2012 01:39 PM
Steve_P
Jan 22, 2010 09:32 AM
EVOIXreno
Aug 6, 2009 03:01 PM
El Boricua
AEM EMS
Apr 13, 2009 12:37 PM
MalibuJack
37
Dec 29, 2004 01:21 PM
