3 lights😞
Old Sep 7, 2015 | 03:44 PM
Marv 97's Avatar
3 lights😞
Hi all im kinda strugleing with this problem ive got an evo 7 and the other day after a little blast or 2 i had the 3 lights come on u no gravel tarmack snow and now when i start the car one comes on then after a few mins they all come on every time not good! I did notice when i got home that the bottle in the boot was way down past min so im thinkin that if the pump was bleed would this pit it bak to normal? Cos i thought it mite of sucked some air in ice read all kinds of stories on various sites sayin the pump is f--ked has anyone had the same issue? Also y does the level drop have i got a leak? Any help would b great thanks anywho!!
Old Sep 7, 2015 | 04:15 PM
Brandisher's Avatar
Sounds like the ACD pump took a turn for the worst. If you drain and refilled the fluid, it won't do anything. Well, it didn't work for me. You might have different results. Your only chices is to replace the ACD pump, rebuild, or go non-ACD.
Old Sep 8, 2015 | 12:48 AM
Marv 97's Avatar
Ive seen the rebuild kits do u know if they are hard to do?
Old Sep 8, 2015 | 03:16 AM
kikiturbo's Avatar
check the rebuild video in my sig..
Old Sep 8, 2015 | 12:13 PM
Brandisher's Avatar
I wouldn't know, I made the attempt but broke something while trying to take it apart. Then I just bought a used one in the FS section.
Old Sep 8, 2015 | 01:47 PM
Marv 97's Avatar
Oooohhhh i c ok well il give it ago and see what happens!! 🔧
Old Sep 8, 2015 | 10:04 PM
evo360bhp's Avatar
ACD rebuilt
I've just rebuilt my ACD pump using a kit and it works fine, although when I was stripping it down I noticed that there were two lugs that are cast onto the main pump body, these broke when I managed to split the pump from the body. Luckily I have a TIG welder with HF (High Frequency) and was able to re-weld the lugs back onto the pump body before assembling the pump. It now works perfectly, mind you, it does take some bleeding through :/
Freebs
Oct 16, 2009 06:19 AM
Sansone
Feb 25, 2009 09:11 PM
Brandnuevo
Jan 4, 2004 11:24 PM
magz
May 1, 2003 10:01 PM
