Evo 5 ABS & AYC Codes
Old Sep 15, 2015 | 04:43 PM
Steven Silva's Avatar
Unhappy Evo 5 ABS & AYC Codes
Hello Forum!
About two months ago I imported a 1998 Mitsubishi Evolution 5 from Japan. Great fun but I failed inspection.
The Issue I'm having is the ABS is constantly engaged when braking. There's no ABS light but there is a AYC light.
When I get the codes out I'm getting..
ABS: 43 Solenoid Valve (RR) System 35B-15
AYC: 65 ABS Monitor System Open or Short Circuit
Anyone know what could be going wrong?
Old Sep 15, 2015 | 05:08 PM
nemsin's Avatar
Your AYC pump is likely kaput. You should consider removing it all together and going with a USDM 8/9 rear diff. There are threads on it on lancerregister.
Here is a thread to get you started http://lancerregister.com/showthread.php?t=359239
Old Sep 15, 2015 | 05:45 PM
Hey Nemsin,
Appreciate the fast response! Gonna try your suggestion out and try tinkering with the pump first.. Trying to keep costs low til' I pass inspection
Don't know if it's related to anything but when I failed the inspection they mentioned that Brake Booster is dead (Causing rough idle too). Think that's related to anything? Or is it a entirely different situation
Old Sep 16, 2015 | 08:18 AM
nemsin's Avatar
Since you are in BC, give John at RockyMountainImports a call. He is in Victoria and has a lot of experience with importing cars and getting them through inspection. He is a very stand up guy and can get your car sorted and through inspection. Tell him Jason from WA sent ya. http://www.rockymountainimports.net/contact-us.php
Rzhang123
Aug 21, 2014 09:54 AM
REV.olution
Mar 20, 2014 08:45 AM
morgeesplease
Dec 9, 2013 08:05 PM
stunt2
Jan 31, 2012 07:45 AM
HiRevnVIII
Mar 1, 2010 05:58 AM
