hks down pipe and apexi exhaust system
Old Nov 23, 2015 | 05:58 AM
kjcs9's Avatar
Im about to install an HKS down pipe which I believe has 2.75" in diameter and match it with an apexi dp back 3" system.
any inputs with this setup?
gains?
is it ok even if the down pipe only has 2.75"?
I need an advice asap since I might install these this week. I don't want to buy and install and re do it again.
thanks
Old Nov 23, 2015 | 05:08 PM
kjcs9's Avatar
anyone?
Old Nov 23, 2015 | 05:16 PM
Biggiesacks's Avatar
Originally Posted by kjcs9
anyone?
Should be fine, it's going from smaller to bigger which is ok. It's when you go bigger to smaller that causes issues.
Old Nov 24, 2015 | 06:48 AM
kjcs9's Avatar
thanks for that. same to what I'm thinking.
or should I go with a 3" dp instead of the 2.75" HKS?
Old Nov 24, 2015 | 10:00 AM
I would say that, unless you are digging into your bottom (pistons and rods) then the 2.75 should be fine. If you factor in other things, like condition and cost, you could probably make a case for the 3". This is probably debatable but going bigger isn't going to hurt you much and gives you more ceiling for modification later.
Old Nov 25, 2015 | 06:05 PM
kjcs9's Avatar
nice. thanks for the help. might just go with the hks 2.75...
does anyone knows how much these costs now? just for comparison since my friend is selling his used hks dp for like 215usd if I convert it from Philippine peso.
dr_latino999
Dec 5, 2016 03:43 AM
need_an_evo
For Sale - Part Outs
14
Nov 28, 2013 07:37 AM
bosshero
Apr 24, 2011 05:45 PM
goevox
17
Dec 24, 2008 10:29 AM
PsychDr. HN$
10
Aug 4, 2008 04:39 PM
