Turbo problem?
Old Dec 8, 2015 | 03:45 PM
PBnJamz's Avatar
Turbo problem?
I was doing some sprinted runs, never WOT. But held boost @ 30 psi 5 times? ASD light lit up. Car was normal the rest of the night until I turned off the car. Next day started it up with it weak.
All AMS O2 parts
Hallman MBC
Down pipe
ETS exhaust
Some AM Injectors
Before:
Held boost @ 30 psi max
Idle 14.7 - 15.0
AFR shoots up to 15.0-16.0 on gas
Turbo whirls normally
Strong pull throughout
Crappy MPG
Now:
Holds boost @ 15 psi max slowly loses psi
Idle 14.7 - 15.5
AFR drops to 11.0 - 13.0 on gas
No Turbo whirl, I can hear BoV and vacuum still
Strong low end pull, weak high end pull
Amazing MPG
Help!
Old Dec 8, 2015 | 03:52 PM
06RedRalli's Avatar
Boost leak?
Old Dec 8, 2015 | 03:59 PM
egis's Avatar
30 psi but not WOT?how much pounds you pushing at WOT? Your X is on limp mode I assume.
Old Dec 8, 2015 | 04:16 PM
PBnJamz's Avatar
If there's a leak I can't find it, I should just soapy water every thing?
Not sure with the numbers, preivous owner didn't leave me the charts. Going to get a retune soon
Old Dec 15, 2015 | 11:56 AM
FTONOOB's Avatar
Could ot be a faulty coupling?
Old Dec 23, 2015 | 08:30 PM
moyassine's Avatar
limp mode!! good luck
Old Dec 23, 2015 | 08:48 PM
PBnJamz's Avatar
Ended up getting cobb ap, but tuner didn't set psi limit..
Old Dec 24, 2015 | 05:24 AM
moyassine's Avatar
problem solved??
Old Dec 24, 2015 | 05:45 AM
PBnJamz's Avatar
For now yes, dropped mbc and picked up grim 3 speed. But I lost 20 whp.. went from 350 -> 330 whp. I definitely prefer having safe boost though. Now if I can fix my occasional erratic idle issue..
Old Dec 24, 2015 | 05:49 AM
moyassine's Avatar
what fuel are u runing?
Old Dec 24, 2015 | 05:56 AM
PBnJamz's Avatar
93 :/
Old Dec 24, 2015 | 05:57 AM
moyassine's Avatar
no access to e85?
Old Dec 24, 2015 | 06:22 AM
PBnJamz's Avatar
e85 is readily available here, I'm looking into getting an e85 tune and freely switching between the maps with cobb ap.
e85 $2.59/g
93 is $2.70/g - $3.00/g (shell)
Red08EVO
Mar 9, 2009 06:57 PM
evoamac
Jun 5, 2007 06:17 PM
ohthree
Jan 14, 2007 07:06 PM
