600hp Evo build
Old Jan 8, 2016 | 01:24 AM
Derek.edstedt's Avatar
600hp Evo build
So guys I'm trying to build a 600hp Evo 8.
Yes yes I know this has been covered a hundred million times, but each build is different (to an extent), but most people don't get too into specifics.
So you know my goal, here's what I have on the car so far:
Built 2.0
Oem crankshaft
BC 625+ rods
Wiseco 1400hd 85.5mm
9.1:1cr pistons
ARP main studs
ACL coated bearings
Balance shaft delete
ARP STD head studs
Cometic head gasket
Stock valves
Brian crower springs and titanium retainers
HKS 264 cams
AEM cam gears
Gates Kevlar timing belt
AEM fuel rail
ID 2000cc injectors
Walbro 450 fuel pump
FP71HTA JB turbo
MAP ported exhaust manifold
MAP elim down pipe with open dump
Tanabe 3" exhaust
ETS 4" front mount
Tial QR bov
Intercooler piping
Halman MBC
Koyo radiator
STM oil catch can
Jacks built tranny
Jacks built t case
I just bought a new coil on plug kit for the car, and a 6266 for her. T3 single scroll.
Now this is my first turbo swap (I bought the car with the 71hta on it), I know I need a t3 exhaust manifold, a new downpipe, a new intake, new lower intercooler piping, or do I? Do the parts I have on it not work with the turbo? I know the manifold won't but wouldn't my downpipe, intake and lower intercooler piping? I'll need oil new oil lines for the turbo considering it came off of an S2K. So my question is what do I need to run 600 on e85? Or can I hit that goal with my parts on pump? I'm in Colorado 6000ft up, so I know the tuning is different than sea level. And last question where do I find these parts? I'm new to this whole thing, I had a semi build on my last Evo but I never made it this far, so what's needed and where do I find it?
Thanks!
Old Jan 8, 2016 | 07:32 AM
Turndown's Avatar
Veteran: Army
I would probably get GSC S2's at least, and the things you listed and you should probably be able to hit 600 after a good tune. The downpipe you have won't work because the MAP eliminator downpipe is for an internally gated turbo, which the 6266 is not... I would recommend going Speed Density as well for a build like that.
Old Jan 8, 2016 | 07:34 AM
Turndown's Avatar
Veteran: Army
As far as where to find the parts... MAPerformance, Buschur Racing, English Racing, ETS, STM etc... There are a ton of places to get stuff.
Old Jan 8, 2016 | 07:38 AM
IzzyRS's Avatar
Have you had any issues with your current valve springs? Maybe get Kigglys or GSC springs if you are going to rev it out.
Old Jan 8, 2016 | 11:55 AM
thepoint4life23's Avatar
Your Going to need bigger cams for sure. but with that turbo on E85 you should make your goal your also going to maybe need more pump. What turbo kit did you buy?
Old Jan 8, 2016 | 01:30 PM
evo8426's Avatar
Does the S2000 turbo spin same direction? My guess is no you won't be able to use it
Old Jan 9, 2016 | 07:43 PM
Yeah I figured I'd buy a 4 bar map sensor and do a speed density tune next time around
Old Jan 9, 2016 | 07:44 PM
It's just a precision 6266 single scroll turbo t3 fitting
Old Jan 9, 2016 | 07:45 PM
No issues what so ever. I usually only rev it out to maybe 7.5k and that's rare if I do that. Most of the time just to redline and I'm good
Old Jan 9, 2016 | 08:23 PM
s4mzxc's Avatar
Got some pics?
Old Jan 10, 2016 | 12:29 AM
Originally Posted by s4mzxc
Got some pics?
I do but every time I upload it a different pic pops up?
Old Jan 10, 2016 | 07:04 AM
Turndown's Avatar
Veteran: Army
Yeah you'll definitely like it better for drivability.
Old Jan 10, 2016 | 07:07 AM
Turndown's Avatar
Veteran: Army
Haha did you get the mexican guy or the O2 housing? I gave up trying to upload pics...
Old Jan 11, 2016 | 10:26 AM
Ceemarsh's Avatar
Cant wait to see pics!
Old Jan 11, 2016 | 05:02 PM
Egsik1's Avatar
In for pics
