NEED HELP!!! Evo loses power randomly
Old Jan 26, 2016 | 07:47 AM
  #31
roni4g63's Avatar
are you running a tephra modified ecu? if so, the check engine flashing could be phantom knock when you disengage the clutch from loud chatter, could very well be knock due to going lean/rich as well, (too lean is my bet tho", anyway, Omni 4 bars are NOTORIOUS for going out out of the blue, its your cheapest try, swap it and let us know, if you're on speed density, i would be money that there is a great chance its the sensor.
Old Jan 26, 2016 | 03:27 PM
  #32
H8WRX's Avatar
Originally Posted by stefenboy
What gap did you have the spark plugs gapped at? What coil setup are you running? If oem coils did you replace the wires?
I am running spark plugs supplied to me by Tom, NGK iridium ones with a gap of 0.18. Running Spoolinup cop. Plugs and coils have only seen 5000miles roughly. All seem to be in good condition when i inspected the coils and plugs 2 weeks ago. Iv been having this issue for maybe 3000 out of the 5000 miles done on these plugs and coils.
Old Jan 26, 2016 | 03:32 PM
  #33
H8WRX's Avatar
Already mentioned that the Map sensor was the cause of the issue, yes i am in SD and will be changing the IAT sensor as well due to already purchasing it when doing trial and error a week ago. I am on a tephra v7 tune. it could possibly be phantom knock but is 100% not a fuelling issue, been down this road with the tuner in the past, my old fuel pump was dropping pressure because it was maxed out or starting to give out. He also taught me that the moment the AFR drops into the 12s when going WOT, to back off. But like i said, fuelling shouldn't be the issue here. When going WOT, it seems to sit comfortable around 11.3-11.6 range, so its getting plenty of fuel.
Old Nov 4, 2020 | 11:56 AM
  #34
R1ch1e's Avatar
Originally Posted by H8WRX
So I own a 2001 JDM Spec Evo 7 currently experiencing some major issues. These issues has only recently occurred within the last week. No mods or changes were made recently. Problem occurred from out of the blue.
The car starts fine and drives fine for the first 10+ minutes until whatever is causing the issue, kicks in. I have noticed the issue only occurs when the car is hot. so if i was to cruise, the issue would take roughly 20 minutes to kick in, do some boosting and you will see the issue in 10 minutes. My Evo will randomly lose all power, not electricity but power in revs. I could put my foot flat in every gear and the revs wouldn't move up a mm, just revs drop to idle and car loses speed until she comes to a full stop then stalls. Once the issue has occurred, the car will start every time no issue but once it starts, she stalls straight away. wait 5 minutes or so, give her some gas as you crank it, she starts and has enough juice to drive for the next 5 minutes hoping home is within reach. Extra- today after changing the crankshaft sensor, test drove and issue occurred, was idling on the side of the road and the car fully turned off. it turned off really smooth that mates in the car thought i turned the key to turn the car off. really confused as i don't really understand what has enough power to turn the car off like that. The car is also misfiring when re applying gas, stalls when coming to a halt and engaging clutch going into neutral and check engine light flashes sometimes, majority of the time is WOT in 3rd or 4th.
PLEASE if anyone has any idea what the issue could be, don't be shy to post. i really need peoples opinion on what the issue could be. The car idles and drives fine until the issue occurs, and i believe it is getting the fuel and air it needs as afr reads fine and she drives and idles fine when cold.
I have done a compression test, all 4 came out mint and healthy. I have tried changing my cop with new coils and plugs, changed Cam angle sensor, had the TPS checked, double checked for boost leaks and just recently purchased and changed the Crankshaft sensor with a new one. None of these components improved the issue. It seems to be getting worse and worse (kicking in earlier and harder to start after the issue has occurred).
My next ideas were to change the fuel relay or intake air temp sensor. But any ideas that could be causing my issue and where to look next would be great. Please help!!
my evo 7 when I put the foot down it boosts for a bit the it stop and feels like I hit a wall can anyone help
Old Jan 20, 2024 | 09:44 AM
  #35
Busta11's Avatar
HI! Maybe I'm breaking some forum rules by reviving an old post... but this seems to be exactly my problem.
I am 24 years old and I had the beautiful but painful idea of ​​buying the car of my dreams, a 2001 Evo 7.
The thing is that precisely the error described in this thread is happening to me... I don't have any knowledge of mechanics but I have been trying hard and reading to understand. ha ha
Where would you recommend I start to try to fix this problem? directly through the map sensor?
chendu1280
31
Dec 26, 2010 01:31 PM
PSM3
May 20, 2008 07:50 PM
r0ck3r
11
Oct 7, 2006 08:39 AM
Luffy
Oct 14, 2005 09:04 AM
