sometimes drive perfect and somce times stall when coming to stop
Old Jan 17, 2016 | 10:51 AM
moyassine's Avatar
hey guys so just needing a little help here. lately my crank broke in half. withought damaging anything, so we relaced it with a brand new forged crank and a new set of bearing. while we are at it i decided to do a different turbo setup. my old setup was just an fp red. my new setup is a 6262 t3 jb with an ets manifiot. tiak wastegate on a ver low psi spring. we finally got the car running. and here we go driving around to break the motor in. not hitting boost just cruising. some times when coming to a stop the car likes to die. it only hapens randomly. i give it a little gas for 20sec then its fine. my afrs read a little lean when it does that, any one might know why?
Old Jan 17, 2016 | 05:58 PM
moyassine's Avatar
anyone?
Old Jan 17, 2016 | 06:10 PM
stefenboy's Avatar
Vac leak? I would check to make sure all your lines are okay. Pcv valve will do that too.
Old Jan 17, 2016 | 06:18 PM
moyassine's Avatar
i just went under there and took a quick look. since im just breaking the motor in i used a vaccum line fron the wastegate to the turbo and i found out it was ripped in half. would that cause it? its too late at night now and i dont have a spare line
Attached Thumbnails sometimes drive perfect and somce times stall when coming to stop-12557214_584835361668204_1512863113_o.jpg
Old Jan 17, 2016 | 06:49 PM
evo.matt's Avatar
are you on MAF or Speed Density?
Old Jan 17, 2016 | 09:09 PM
moyassine's Avatar
i am currently on maf. once all the problems are figured out it will be on speed density
Old Jan 19, 2016 | 01:13 PM
usrocket's Avatar
This could be a number of things starting either with the tune and/or you must check your idling components to see if they are clear of debris. Good luck.
sgambino92
May 27, 2018 07:30 PM
GT45R Supra
Feb 14, 2017 05:16 PM
coreymelton
May 16, 2015 05:41 AM
EM1 to EVO
Oct 13, 2008 06:35 AM
