Seeking advice vibrations
Old Jan 25, 2016 | 06:44 AM
adawang's Avatar
slight shaking / vibration
can be felt on car seat
no shake on steering wheel
speed of 20 to 80 kmh
Mitsubishi Evolution 9 Wagon Auto
year 2006
1st owner
Jan 2015 , went over a piece of wood on the road
dented the front left rim at the inner lip, tyre burst
dented the rear right rim at the inner lip
have changed the following
the 2 dented rims, original Enkei
4 new tyres, Goodyear F1
new engine & transmission mount 4 pieces
new prop shaft centre bearing 2 pieces
front and rear half shafts remanufactured at the drive shaft shop.
new wheel bearing 4 pieces
DEc 2015
new front Bilstein shock absorbers 2 pieces
Happiness but smooth shake free driving lasted only 2 days.
Does a pair of front Bilstein last 2 days?
so it continues
Jan 2016
new rear Bilstein shock absorbers 2 pieces
When on the hoist, engine running in D, could see the front left wheel has a slight side to side movement ,
viewed from the front of the car
new knuckle - 1 piece front left.
suspected the left cv shaft, removed and rotate it on the lathe with the outer cv joint on.
could see the shaft shake.& was told that it is normal as the outer joint would cause the shake when
spinning on the lathe.
visual inspection does not show it is bent.
another set of tyre, Michelin, due to uneven wear - Jan 2016
Any ideas or assistance appreciated,
Should I go for original CV shaft?
chuggychug
Dec 23, 2009 07:09 PM
Autumn Tactics
12
Nov 7, 2004 08:55 PM
Autumn Tactics
Nov 7, 2004 08:47 AM
Autumn Tactics
Nov 6, 2004 05:41 PM
Rnm
14
Oct 9, 2004 01:02 PM
