Vibrations! Help, need advice!
Old Dec 22, 2009 | 08:16 AM
chuggychug's Avatar
All,
Tis the season for snow. At least the NE Coast. We got hit hard. I was pulling out of my garage and into the blizzard to get some shopping done. The car was driving fine, but then again, it was all local roads, therefore I was going no faster than 40mphs. However, yesterday I went onto the highway and started to get above 60mphs and noticed the steering wheel to vibrate. It got worst and worst as the speed increased but calmed down when I decelerated below 60mphs.
I assumed, it several possibilities:
1. My alignment is off and I should my tires rebalanced/aligned.
2. Snow packed in the tire-well?
3. I'm FUBAR
Thanks for the advice mates.
Cheers,
Chug
Old Dec 22, 2009 | 08:19 AM
Bobster22388's Avatar
Sounds like you got snow packed in your wheels most likely causing them to be off balance. I had the same thing the other day in the snow once I got up to speed. Cleared it all out, and everything is all good now
Old Dec 22, 2009 | 08:20 AM
halfnhalf83's Avatar
tires need to be balanced...
Old Dec 22, 2009 | 08:31 AM
Wheel weights do not usually just fall off. Way more likely to be just snow packed in there. Especially with driving in the snow, then having this happen, and being fine the day before.
Although if the car has been in a garage and the snow is all melted and there isn't any there, then you will need to get the wheels re-balanced as the snow could have knocked off a sticky weight if you have them.
Old Dec 22, 2009 | 08:39 AM
chuggychug's Avatar
Thanks guys. Yeah, it was garaged, but then again. I drove in about 1 - 2 feet of snow and thats when it started to get all weird on me. But it seems the vibrating went away after spending a night in the warm garage. Most likely the snow packed in there. Will keep an eye on it to see how things pan out.
~Chug
Old Dec 22, 2009 | 08:41 AM
^^ im aware of that.... but obviously the balancing has been thrown off, be it snow..or weights.. ^^
Old Dec 23, 2009 | 05:04 PM
So you would re-balance them even though it was just snow is basically what your saying here...
Old Dec 23, 2009 | 05:10 PM
lmao...no. i clearly stated the balancing was thrown off. if the snow melted and all is good, fantastic he needs to do nothing. if the snow melted and the vibration as he described is STILL there...id say yes they need to be balanced again.
make sense now? lol
he resolved the problem anyway...or so it sounds.
Old Dec 23, 2009 | 07:09 PM
Kracka's Avatar
Snow in your wheels.
dragon831
Dec 20, 2011 12:48 PM
PATRICK B.
Dec 16, 2011 08:52 PM
AboodsEvo
Nov 19, 2010 03:30 PM
TurboIX
24
Jul 22, 2009 06:21 PM
Turbojunkie
Jun 28, 2009 09:46 AM
