Evo Maf help
Old Mar 31, 2016 | 10:34 AM
Ant1's Avatar
Evo Maf help
My idle sounds like I have after market cams and it sounds like the car is missing and smells rich.
If I disconnect the maf and hold the revs (otherwise drops to 300rpm) using TB engine sounds smooth and normal.
Can I assume it's the Maf at fault?
Old Mar 31, 2016 | 11:40 AM
evoerik89's Avatar
Mine just crapped out a few weeks ago. Same issues kinda like you and i unplugged the MAF and symptoms were the same. Swapped one out with a freind and wah lah. Good luck with the issue tho
Old Mar 31, 2016 | 12:19 PM
roni4g63's Avatar
im sure if you keep the MAF plugged and hold the throttle it would stay consistant too?.. perform a boost leakdown test, sounds like you have a big vacuum leak, if that checks out, take your UICP off, and look to see if your throttle body/ intake manifold are clean.
Old Mar 31, 2016 | 12:24 PM
Ant1's Avatar
If I leave the Maf plugged in and and hold the rpm steady it misses, lumpy idle like crazy, so no completely different
Old Mar 31, 2016 | 07:11 PM
Bhsj13's Avatar
I just got my car back.
symptoms i had:
-rough idle
-misfire
-fuel cut feel at low load
-bogging at idle
-bogging at low load normal driving
-afr's pegged out lean and then rich (back and forth)
i thought it was spark plugs so i replaced them with no results. then, i thought it was fueling so i replaced the fuel pump and sock filter with no results. took it to the shop (all aspects motorsports). map sensor was losing signal randomly and changed it with no results. threw on someone else maf and it drove perfect. bought a new maf and installed, now it drives like new again.
get a hold of someones maf and try it out. might just be it.
Old Mar 31, 2016 | 07:47 PM
Dr. Jekyll's Avatar
I agree with you and Bhsj13 and am guessing that your MAF sensor is at fault. But, assuming you have an AccessPort (or similar) you could test it by disabling the MAF sensor input, forcing the ECU to, exclusively, use the MAP sensor for fuel calculations. If the problem persists, the issue is more serious (likely a boost leak). If the problem improves/disappears, get a new sensor and get back to goin' fast!
Old Apr 5, 2016 | 02:24 PM
Bhsj13's Avatar
OP, did you figure this out?
chaotichoax
26
Jun 28, 2011 11:20 PM
anthonyrb98
16
Mar 17, 2011 07:44 PM
boostedwrx
Dec 30, 2010 10:32 AM
pbevo12
43
Dec 6, 2007 11:35 AM
MitsuJoe
Aug 27, 2005 07:36 PM
