What size fuel pump?
Old May 19, 2016 | 07:22 AM
lancerrally45's Avatar
You need a dual voltage rewire. The easiest way is to use a hobb's switch to activate a 10g supply from the battery and splice into the pump power wire right at the sending unit. mrfred has a thread on it in the how to section.
https://www.evolutionm.net/forums/ev...e-circuit.html
A very good read.
Old May 19, 2016 | 07:55 AM
Speedlimit's Avatar
Admin Emeritus
Originally Posted by 3gturbo
edit -golgo13
Hi,
Kindly put your gloves back on and refrain from personal insults. Thanks!
Bob
Old May 19, 2016 | 09:30 AM
ISPEVO8's Avatar
Thanks for the input exactly what I was looking for only other question I have is if anyone knows how many amps the pump draws with the rewire, I see that it draws 14.1 amps at 13v. Just wondering if I can get away with a 15amp inline fuse or if it will be cutting it to close to the threshold of the fuse
Old May 19, 2016 | 04:51 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Thread cleaned. Keep things civil, thanks.
This is a family show.
Old May 20, 2016 | 04:56 PM
whtrice's Avatar
Veteran: Air Force
CrazyLilPunk
Apr 24, 2016 04:17 PM
MisUnderStood
Dec 16, 2015 08:53 AM
Carloverx
14
Dec 22, 2011 01:00 PM
turboDan
Dec 28, 2006 09:48 PM
