Evo Rolling Coal
Old May 10, 2016 | 07:45 PM
BbotVIII's Avatar
Evo Rolling Coal
Hey EvoM, I had gotten my 2004 evo 8 tuned back in September of 2015 and have been loving it. Recently I have been noticing quite a bit of black smoke in the rear view when I do full throttle pulls. The car even throws a ton of sooty smoke when I use 2 step. I don't believe it is tune related because the car never used to do this then it was freshly tuned. I have not noticed any loss of power my boost stays consistent at around 26lbs and my afrs seem to stay right in the 11-11.5 range which to my knowledge is normal. nothing feels different other than my car throwing smoke similar to a cummins 😂😂 my thinking would be a boost leak or a pre-turbo exhaust leak?? but wouldn't these make my afrs drop?? I am very confused hahah any input on how I should diagnose this problem would be helpful.
Thank you, Brian
Old May 10, 2016 | 08:34 PM
Biggiesacks's Avatar
generally black smoke is oil burning, white smoke is coolant. Could be your turbo leaking oil, could be the engine burning it. Or it could be something else, but i would cross either of those things off the list if you can.
Old May 10, 2016 | 08:48 PM
barneyb's Avatar
One day I blew the intake hose off of the throttle body. Having no tools, I drove the two miles to home. Other than barely running, the result of the drive was a black rear bumper. So, check for a boost leak.
Old May 10, 2016 | 09:32 PM
roni4g63's Avatar
Black smoke is fuel, blue smoke is oil.
Check your fuel trims with a basic scan tool, if they are +, there is a vacuum/boost leak somewhere. If the car is on ecu boost, it will make the required boost regardless of leaks, it will put a heckof a strain on the turbo tho.
Anyway, if you wanna make sure its not oil. Do a compression test. Yes pre turbo leaks will cause lean afr's. You most likely have a small boost leak.
Old May 10, 2016 | 09:42 PM
or yah blue,.... im not great with black/blue lol but op said his afr's are normal and its smoking alot. Maybe he is bad with colors like I am lol
Old May 11, 2016 | 03:39 AM
Jonno99's Avatar
Stop posting on the net and get your compression tested and turbo oil seal checked!!
Old May 12, 2016 | 06:04 PM
hutch959's Avatar
when i first got my car it smoked horrible at wot. I thought it was oil. It was not....
after the tune was corrected, all smoke went away.
EvoBaja
Nov 26, 2011 01:52 AM
Kyl3cook
Feb 7, 2006 04:44 PM
Blue Evo 8
Oct 17, 2005 07:27 PM
Jounin
Mar 11, 2005 04:28 PM
