Evo 8. Big turbo, big fuel, big power
Old May 16, 2016 | 07:35 AM
xxst1tch3sxx's Avatar
Hello! Recently I purchased an evo 8 under the idea that it needs a new engine. Cylinder 4 was measured at having around 130psi while the rest where 160psi. That being said this car is a highly modified car. Currently running e85, 1650 injectors, ams900x, speed density, and other supporting mods.
That being said; this car was brought up from Texas where e85 is much more available then where I live in MA. Short of tune is there anything else I should account for when "downgrading" to 93?
Old May 16, 2016 | 08:21 AM
josh_evo9's Avatar
I would say possibly injectors, depending on how well those 1650's will run on pump. Also, if you plan to rebuild the engine to its current spec, I would figure out the compression ratio. Then see how you want to rebuild. Alot of pure e85 builds have higher c/r than pump gas.
Old May 16, 2016 | 12:34 PM
Turndown's Avatar
Veteran: Army
Go with an FiTronic flex fuel kit from TSComp that way you can run it when you're around a gas station that has E85 without having to worry about switching MAPs. I live up in Melrose so I know the struggle. If you live anywhere near Boston, there are stations all around the Pike with E85
Old May 16, 2016 | 01:04 PM
Thanks for the advice Josh! And Turndown I live in Worcester. My nearest option is like Charlton on the pike. I planned on doing flex fuel but right off the jump just wanted to ensure I didn't need to account for anything else other than tuning to revert back to 93. Plan is to make less power because I have 0 need for the same power this thing made when it was running correctly haha
Old May 16, 2016 | 01:10 PM
Turndown's Avatar
Veteran: Army
You could easily have it tuned so that you aren't making crazy power too. With the cost of a tune, might as well get both in case you ever have the desire to throw some E85 in and not have to touch anyhting to make more power. Just a thought!
Old May 16, 2016 | 02:18 PM
I absolutely appreciate the input! I supposed we shall see how it plays out once the engine is out this weekend and from there assessed for damage.
Old May 16, 2016 | 05:06 PM
Turndown's Avatar
Veteran: Army
Sure! Keep us updated.
Old May 19, 2016 | 06:23 AM
Ran my own compression test because the previous owner went off what he was told by the shop. Results are as follows 115,125,120,100. Warm engine and throttle at 100%. Maybe I will get lucky and it'll just be the headgasket lol. Hopefully get my hands on a compressor today and can perform a leakdown before the weekend.
daechul2da
13
Oct 13, 2012 11:07 PM
Maximum Output
42
May 24, 2010 11:30 AM
Evokid03
Nov 6, 2009 06:04 PM
turboDan
Oct 16, 2007 05:56 PM
AndyC
19
Apr 26, 2005 04:09 PM
