Geting Tired of Small Power and Feeling the need for Big Power
Old Nov 5, 2009 | 10:35 PM
Evokid03's Avatar
Hey guys, as you all know.. my little evo 8 has been pushing a stock evo 9 turbo as much i can. Ill completely be hoenst and say i love the car, but im at the time in point where i want to get crazy.
Ya i know its alot of money but, with time and dedication anything is possible.
I wanted to open this tread to here peoples thoughts on what turbo/manifold setup i should run.
I have plans on running a Br 2.1 built block, Its winter time and im starting to save a good amount of money.
All comments and ideas would help conclude my next setup
Current Setup
STock Block
Stock Head
Evo 9 Turbo Ported
Ported Exhaust Mani
Br ported Intake mani
boomba 65mm Tb
Br Uicp
Ams licp
Ams (knock off) Fmic
Strictly Mod fuel rail
fic 1050cc injectors
Tial bov
Full 3" exhaust (Invidia)
Fp4r cams
Arp head studs
Beehive springs/ retainers
megan o2 housing
walbro fp
Civic Half Sized Aluminum Radiator
e85 tune 27psi
Then i have the extra supporting mods
Avid Motor mounts
Energy Trailing arm bushings
Solid Rear Diff bushings
Solid Driveshaft bushings
Quartermaster Twin disc clutch
STainless upper clutch line
Shifter bushings
Short shifer
Counter weight shift knob
blah blah lol
I might have more but im forgeting lol
my new list as i plan on building (Comments Apriciated)
Br 2.1 Block
Get a build Head Br stage 3 (if not leave it stock with fp4r cams for now)
Forward Facing Manifold ( i want a forward facing capable of using a filter) Brand Unknown --comments here
Turbo (No idea) ---comments here
Tial 44mm Wastegate
Awd aluminum Driveshaft
full blown double pumper or br setup
bigger injectors possibly 1600cc
If you feel any other parts should be added or changed plz feel free to comment.
I wil be parting out all my stock turbo setup very soon on my car so i can complete my little project
Old Nov 6, 2009 | 11:34 AM
SBR INC's Avatar
that's a big jump man, I would suggest you get some cams and retune, it'll help net you some good power and torque. Aside from that, the new setup will definitely make more power.
Old Nov 6, 2009 | 11:44 AM
ToMuchBoost's Avatar
Your going to need a good clutch exedy twin hd would do the trick. As for the turbo your going to need something that can push some air. Since you will be reving pretty high with the 2.1. A hta 86 or 6262 or bigger would be good. Also i would look into a shep trans also because its going to break sooner or later with a setup like this.
You could run it with the stock ecu for awhile but you will pick up more power with a AEM ems or the hks one.
Old Nov 6, 2009 | 11:51 AM
heel2toe's Avatar
You might want to consider upgrading you FMIC to something a little more efficient.
Old Nov 6, 2009 | 11:58 AM
dtrackstar's Avatar
maybe a new tuner?! haha jk...kunal does a great job! good luck with your build, keep this thread updated
Old Nov 6, 2009 | 05:23 PM
YogSaahoth's Avatar
Veteran: Army
why not give the red a try, or even the new fpblack...the red has been proven to make ~500whp with good cams on e85 and stock block. with a 2nd fuel pump and 1600s you could make big power (i consider 500hp big) with minimal lag and a fraction of the cost and labor. now, if you want the built motor/t3 setup, by all means go for it. lord knows i would love that myself...but i think the red w/ e85 is an oustanding street setup and deserves some consideration.
that said, if ur gonna go with the forward facing mani, which is dead sexy, like my man said above try the 6262 or hta86. i dont know if youve seen any results on here but people are making unreal power with these relatively fast spooling turbos. the pte billet turbo lineup is really very impressive, and have a range of sizes both smaller and larger than the popular 6262. goodluck
Old Nov 6, 2009 | 06:04 PM
Evokid03's Avatar
ok, lets start answer questions
First off i have a quartermaster twin disc clutch in the car that is absolutly grippy
SEcond off, i plan on purchasing a buschur race fmic w/ licp as soon as i upgrade the turbo
Car already has cams
Forced performance fp4r cams which r pretty aggresive
i considered a fp black, but i just see my self being happier overall with a nice big turbo setup
Im all about power as Kunal would pitch in to aggree.
Ive kept the car to its point so i could build around the motor first then go crazy
Also i wanted to get used to the car since it was my first evo.
Btw i am looking into the Buschur (shearer) Forward FAcing Manifold as it looks wicked
The two turbo's i was considering actually is the 6262 or the hta86. But you guys think that will be enough lol
David Buschur
Nov 16, 2015 09:35 AM
FL_SilverEvo8
74
Aug 27, 2012 11:38 AM
GGevo921
Jul 28, 2012 03:31 PM
StreetThisEvo
171
Jul 28, 2011 02:39 AM
David Buschur
Jul 12, 2010 04:14 PM
