Cam Shaft Seal Install?
Old Jun 21, 2016 | 07:28 PM
EVOEvolved's Avatar
I am trying to figure out if there are any easier ways to install the cam seals on the EVO 8 besides take the timing belt off and resetting the timing?
Possibly holding the timing belt with crimps, but then I can imagine that the slack being taken up with force the belt back down. I am sue ill have to just take the belt off etc and retime the engine, but I was not sure if there was possibly a better way.
Old Jun 22, 2016 | 09:07 AM
lancerrally45's Avatar
MI! Where abouts?
Zip tie the timing belt to the gears. Take tension off the tensioner. Remove cam bolts. Move parts away from head. Take out cams. Fairly easy.
If you're close I can help out. I have all the toolings for timing, etc. And for the amount of times I did a timing job, I can probably do it blind if I had to.
Old Jun 22, 2016 | 09:13 AM
Biggiesacks's Avatar
^^ that. Zip ties and the tensioner tool are all you need. Well and some hand tools. There is a video floating around on youtube on how to swap the cams without re-timing the engine. Basically the same thing you need to do to change the seals.
Old Jun 25, 2016 | 07:47 PM
EVOEvolved's Avatar
Originally Posted by lancerrally45
MI! Where abouts?
I am in muskegon 😇- cam shafts have to all the way off?!
Old Jun 25, 2016 | 09:02 PM
The gears themselves have to yes.
snowborder714
For Sale - Miscellaneous Automotive
May 6, 2017 06:22 AM
EvoIIIAj
Jul 18, 2013 06:42 PM
evascst
Sep 12, 2008 06:54 AM
gt420hp
Northeast Region
Sep 17, 2005 08:03 AM
