Help oil on spark plug!!!
Old Jul 2, 2016 | 11:11 AM
inshallah's Avatar
2003 evo 8
130k miles
the motor is all original from what i know but it has had cams installed at one point
HKS 264's
my issue started when it started breaking up WOT so i changed plugs but when i looked at the first plug near the cam gears, it has oil on the spark area. to the point where it has turned black.
after changing the plugs the issue came back a month or two later. my guess is the valve cover gasket along with the spark plug gaskets need to be changed?
some shops started telling me my head needed a rebuild and so forth.
compression test was done and 150 across all 4 cyl
no leak down yet.
any input would be nice thank you
Old Jul 2, 2016 | 03:47 PM
maxpayne159's Avatar
Are you sure it's oil build up on your spark plug? Is it possible you're plugs are gunk build up from running rich? When I changed my spark plugs I would say they look dark and dirty but I wouldn't say they are gunk like. I'm naturally assuming you know which kind of spark plugs to get for a evo
Old Jul 2, 2016 | 04:17 PM
twabtoxer's Avatar
Could be gaskets, also make sure the valve cover bolts are fastened tight
Old Jul 4, 2016 | 08:06 AM
06RedRalli's Avatar
I'd start with the easy/cheap option first and get a new valve cover gasket w/ the spark plug gaskets as well. Oil could easily be getting past the gasket causing your issue.
Old Jul 5, 2016 | 07:52 AM
heel2toe's Avatar
Where is the oil on the plug? can you snap a picture? If oil is on the electrode then you could have some serious issues however is the oil is on the insulator then its just your valve cover tube seal that's leaking. Fingers crossed it is that as that is a simple cheap fix.
Magrud3r
Sep 25, 2014 06:22 PM
AWDBus
Dec 8, 2011 11:01 PM
fimotorsports
Nov 19, 2007 01:55 AM
QAT-R
Aug 31, 2006 11:05 PM
SlowCar
Dec 30, 2005 04:07 PM
