My Evo 9 stock turbo boost inconsistent
Old Aug 10, 2016 | 03:20 PM
v8<turbo4's Avatar
So I don't believe my car has done this till recently I have a full bolt on Evo 9 with cams ect. Stock turbo MBC and 1000cc injectors.
93 tune When I go wot I get boost hitting 1.5 bars then falling down to 1.1 then at redline it hits 1.5 again but the midrange I can feel the boost falling off and power dropping. Also I should mention my tune on 93 is suppose to be 24-25psi so it's 2-3 pounds off the peak boost numbers
Any ideas. Car has a dual map tune one for 93 and one for E85
Old Aug 10, 2016 | 03:37 PM
Evo_Goodness's Avatar
Does it do the same on E85 if it does then you know it's a mechanical problem if it doesn't then it's a tune issue
Old Aug 10, 2016 | 03:45 PM
v8<turbo4's Avatar
I haven't ran E85 yet since I noticed the problem. I'm also have a problem with my AFR being a little inconsistent.
I will have to try out E85 when I can get my hands on some
Old Aug 10, 2016 | 04:14 PM
Biggiesacks's Avatar
Have you done a boost leak test? If not, do a boost leak test.
Old Aug 10, 2016 | 05:53 PM
Yes a boost leak test would be the first thing check all lines by the fpr around the intake and IC couplers
Old Aug 11, 2016 | 10:53 PM
Redline-Z's Avatar
Veteran: Air Force
I got $20 your TB is leaking badly....
Old Aug 12, 2016 | 09:02 PM
v8<turbo4's Avatar
hey guys got back and drove the car for the first time since X mass and all the problems are gone looks like it was just from the cold weather the tune won't adjust i guess pretty ****ty but on the bright side i won't ever need to drive the car in the winter.
ZZEVO
Jun 5, 2018 07:34 AM
hung861988
Feb 13, 2015 04:45 AM
eb66
Jan 23, 2010 12:00 PM
ExViTermini
15
Jan 18, 2006 08:04 PM
