Evo 8 GRS to evo 8 Mr engine swap.
Old Aug 20, 2016 | 12:36 PM
xxmachineshopxx's Avatar
So I recently did an engine swap to an evo 8 Mr engine. The car starts up and idles fine but once I start driving it won't go pass 3k rpms and starts lossibg power and bogging. Ive check for boost leaks and there were none. I was previously tune and kept my old ecu in car. Need some help kinda stumped right now.
Old Aug 20, 2016 | 02:40 PM
superbovine's Avatar
Anything different on the old engine that you were tuned for? Example, old engine had cams or bigger injectors, new engine does not?
Did you personally witness the new engine running normally in the donor vehicle (in case it behaved the same way in another car, could be jumped time, low compression etc)?
Old Aug 20, 2016 | 02:54 PM
Biggiesacks's Avatar
sounds like your running tephramod v7 and its in valet mode
Old Aug 21, 2016 | 01:45 PM
To add more info the car idles fine but at time will be rough. There is a loud whining sound coming from the fuel pump area. I drove it around a bit today and it was driving normally for about 15 min until it started hesitating which lead to going back to the same issue. I was not able to go past 3k rpms without the car bogging again. I am tuned to stage 2 with no real major mods.
Old Aug 21, 2016 | 06:21 PM
stefenboy's Avatar
New spark plugs? Whats the gap of the plugs? Did you reuse the coil? Coil on plug setup? Are you on sd? Maf? There is alot that can cause this but if it was driving fine before the swap and now doing this after the swap, i would think about what you reused and what you didnt reuse.
evo-2014
Cobb AccessPORT
Mar 10, 2015 07:48 AM
Yoga_EVO
Nov 8, 2014 02:32 PM
rober_x
Dec 20, 2011 06:23 AM
importdps
Import DPS - Philadelphia, PA
Jul 28, 2010 08:41 AM
