EVO Recall: weight Label.
Old Mar 31, 2004 | 06:05 AM
Airborne's Avatar
Exclamation EVO Recall
I just received this a few minutes ago:
RECALLS
2003 Mitsubishi Lancer Evolution Sedan Select Different Vehicle
1 Recall Notice
These recall notices may not apply to all vehicles. Please contact your dealer for more details or contact the National Highway Traffic Safety Administration's Auto Safety hotline at 1-888-DASH-2-DOT (1-888-327-4236).
Campaign Number: 04V138000 Date: 2004-Mar-25
Component: Equipment: Other: Labels
Defect Summary: ON CERTAIN PASSENGER VEHICLES SOLD IN THE UNITED STATES AND PUERTO RICO, THE GROSS VEHICLE WEIGHT RATING (GVWR) AND GROSS AXLE WEIGHT RATING (GAWR) AS STATED ON THE CERTIFICATION LABEL ARE IN ERROR.
Consequence Summary:
Corrective Summary: DEALERS WILL REPLACE THE LABEL. OWNER NOTIFICATION IS EXPECTED TO BEGIN DURING APRIL 2004. OWNERS SHOULD CONTACT MITSUBISHI AT 1-888-648-7820.
Old Mar 31, 2004 | 06:53 AM
GOKOU's Avatar
false labeling could lead to LAW SUIT
I need to bring the car back in for the o2 sensor recall so I guess they can do both at the same time.
Old Mar 31, 2004 | 07:03 AM
MSanad's Avatar
Re: EVO Recall
Thank you for notifying us AIRBORNE!!!
RECALLS
1 Recall Notice
Old Mar 31, 2004 | 07:16 AM
mifesto's Avatar
yeah i remember when evo first came out, people were saying the evo weighed 4000+ lbs (based on labels and manual)... which made no sense because car and driver tested it for about 3200 lbs..... i think mitsu is just correcting a dumb mistake/typo.
Old Mar 31, 2004 | 08:22 AM
DB8GSR's Avatar
If it did weigh close to 4000lbs per the sticker, then we must have one of a heck strong motor to pull the stock Evo onto the 13 second range.
Old Mar 31, 2004 | 08:27 AM
blonde's Avatar
thanks for the info. any recall IS important.
i will stick this thread so all the people can see it at least for the next couple of week and i will also edit the title to be more specific.
thanks
Snir
Old Mar 31, 2004 | 10:00 AM
Secret Chimp's Avatar
Thanks for the heads up airborne.....
btw, the only people who were saying the Evo weighs 4k were people who didn't understand how to read the door sticker. The GVWR is NOT the weight of the car. Its the maximum weight of the car including passengers and cargo....ie, when the car is fully packed, if it weighs more than the GVWR you are exceeding the limits of the vehicle.
SC~
Old Mar 31, 2004 | 10:14 AM
mifesto's Avatar
true B secret chimp...
Old Mar 31, 2004 | 02:37 PM
RallyRedEVO's Avatar
So just how much does the car with sunroof/wing weigh in at with gas and everything in it? Because the factory weighs it without fluids right?
Old Mar 31, 2004 | 06:10 PM
frogstaple's Avatar
On our truck scale at work that only measures to the nearest 20 pounds, my Evo with CF wing, no sunroof, and a half tank of gas weighed in at 3280 pounds.
I also measured one corner at a time to check the overall balance. The numbers don’t add up to 3280, but it gives you a rough idea of the distribution.
left front=960 pounds
right front=980 pounds
left rear=660 pounds
right front=640 pounds
Old Mar 31, 2004 | 09:14 PM
JRock's Avatar
wow is the Evo's weight distro really that uneven? that's like 66:33 which is worse than most cars around. one would think on a front-engine performance car it would be more around 52:48
Old Apr 1, 2004 | 12:47 PM
Chris in HB's Avatar
Yep, the Evo still sucks. It is front heavy, as is the STi. All that gear up front adds up. That's the reason I still have the spare in my trunk (to keep the weight somewhat balanced). I believe the factory quote is 60/40 f/r.
Old Apr 2, 2004 | 09:40 PM
mprtklr's Avatar
here is the rest of the recall..
"GVWR is incorrectly rated at 4422, and it should read 4222. front should read 2270, not 2249. the rear should read 1995 instead of 1973. This was a MMUSA internal investigation recall, and NOT proported by NHTSA.
Old Apr 3, 2004 | 03:11 AM
Cirrusly Evolvd's Avatar
Weighing one wheel at a time is innacurate. You need to weigh the front two wheels together and the rear two together. Add up that weight for your total.
Old Apr 3, 2004 | 07:59 PM
XVIIIXM's Avatar
I wonder if the state of NJ is charging accordingly for the mislabel. Anyone reregister for a truck's weight and fee?
