Need advice on cams
Old Oct 11, 2016 | 03:39 PM
Bman513's Avatar
Need advice on cams
im going to be running a pte 6466 turbo and need advice on what the best cams would be. Been looking at gsc s2 but am unsure. Any advice is appritiated
Old Oct 11, 2016 | 03:56 PM
LetsGetThisDone's Avatar
need to know a lot more about the build than just the turbo to recommend cams...
Old Oct 11, 2016 | 04:56 PM
Pal215's Avatar
what he said^
Now that we know your turbo, answer these questions:
What is your motor displacement, built or stock head, if built what parts? Drag or track, what will be your rev limit? Evo 8 or 9? Mivec head ?
-pal215
Old Oct 11, 2016 | 08:57 PM
Bman513's Avatar
Originally Posted by Pal215
what he said^
-pal215
2.3 stock head right now, will be adding springs and retainers with cams, street car, 8k, 9 mivec
Old Oct 12, 2016 | 12:58 PM
Pal215's Avatar
I'd sell you my cosworth M3's but honestly those are much better for a lower displacement and high reving engine.
I would look into GSC S3 or GSC R2 if you have the proper valve seal clearances. In either case you will have to upgrade your valves, valve springs, and retainers.
Stick with the new billet cams as they are stronger than their cast counterparts and offer greater reliability, especially for the Mivec cam.
Check out this thread for more info, all of our specs are similar.
https://www.evolutionm.net/forums/ev...-s3-vs-s2.html
-pal215
Old Oct 12, 2016 | 11:10 PM
17pstockcar's Avatar
Go with r2 with springs retainers and new valves
Old Oct 13, 2016 | 09:29 AM
2.3 gets R2's.
Old Nov 26, 2016 | 07:54 AM
Chris Smith's Avatar
r2
otbEVO
20
Oct 7, 2010 02:18 PM
cbell386
Aug 17, 2010 09:22 AM
evilrevo8
Jul 7, 2009 02:06 PM
Gruppe-S
18
Oct 23, 2006 11:10 AM
