Having loud ticking noise on my evo 8 (help)
Old Oct 26, 2016 | 09:21 PM
samredka's Avatar
https://youtu.be/Lmol40iBDHc
here is a video I took , of the the current noise going on .
Some me general info on my Evo :
after full rebuild , forged internal about 3-4K miles in .
1200cc Inj.
Hks 284 cams
just swapped evo 9 turbo on it
fullt greddy exhaust
anyways hoping its a lifter Rick noise. , but from over videos I saw on lifter ticking this seems louder and it gets louder as I rev the engine .
I would be very surprised if the engine would need to be rebuilt as I just got it rebuilt and did the proper oil changes .
Only thing I could think of is mabye timing skipped since I should've probably gotten a tune after a while ago with the things I've done to it . Or exhaust leak through mani since I reused the metal mani gasket . But I don't think it would get that loud .
I would appreciate all your input . I will be taking it to the shop soon , I just don't want it sitting in the shop as they charge me for all the time it takes to figure out the problem in all the different processes it could take to figure it out
Old Oct 26, 2016 | 09:44 PM
Biggiesacks's Avatar
pull the timing cover and get a wrench on the crank. Make sure the timing marks all line up properly. Also what does the oil look like? Kinda sounds like rod knock.
Old Oct 26, 2016 | 11:29 PM
kaj's Avatar
kaj
kinda hard to tell by the vid, but sounds like rod knock unless you can be sure the sound is coming from elsewhere.
I use a stethoscope to pinpoint noises. Most auto parts stores sell ones with metal rods attached that you use to touch various parts of the engine. It will be very obvious where the sound is coming from, if you have any doubts now.
Does your oil have any visible metal pieces in it? Flakes, etc?
Old Oct 27, 2016 | 02:43 PM
samredka's Avatar
Damnit , where did all my oil go
Old Oct 27, 2016 | 02:50 PM
SilverShadow03's Avatar
Drain the remaining oil, replace oil and install a new oil filter, start and see if the sound goes away.
Check drained oil for shavings.
Old Oct 27, 2016 | 03:01 PM
samredka's Avatar
Will do that right now already got the oil . Will hope for so metal and hopefully still good compression , this noise just started 4 blocks from my house . Hopefully it's still good
WikdEvo
23
Dec 11, 2015 08:30 AM
aftershock141
Sep 30, 2011 08:46 PM
Blitz
18
Dec 31, 2009 03:14 PM
Oli
12
Aug 2, 2006 04:23 AM
JaReDbOy
15
Mar 17, 2006 08:14 AM
