⛔★ Evo 8 5sp, whats the door on the bottom on transmission for?
Old Nov 1, 2016 | 03:27 PM
supak1111's Avatar
⛔★ Evo 8 5sp, whats the door on the bottom of transmission for?
Hey guys I just noticed my 5sp trans has a little small leak out of the little door/cover on the bottom of the transmission with maybe 5 10mm bolts hiding it in place.
Was wondering if there was any sort of filter in the transmission under this door, like you would find in an automatic trans?
Whats the door for anyways if not filter? Is there a gasket under the door or do I just use some liquid gasket to fix the leak?
__________________________________________________ ________________
★★ Signature: ™007-License-Plate-Hide-Kits by: http://007Plate.com/evom ™★★
Old Nov 1, 2016 | 03:34 PM
LetsGetThisDone's Avatar
Its an access panel to remove the reverse idler gear. the reverse idler has to be removed before removing the shafts, that's why the access panel is there. It is sealed with silicone. I doubt its leaking. When the trans is filled, excess fluid that comes out of the fill hole collects on the lip of that thing. Just spray it off with brake cleaner. If fluid returns, then consider draining the trans and pulling it off to reseal it.
Old Nov 1, 2016 | 03:50 PM
supak1111's Avatar
Ahh ok. I cleaned it once 2 months ago, just did an oil change and saw it was slightly wet again. I need to do a trans-oil change so I'll just reseal it when I'm down there anyways.
Thanks
DarksideEng
Lancer Ralliart Vendor Classifieds
42
Apr 23, 2013 06:34 PM
DarksideEng
11
Aug 4, 2009 12:44 PM
DarksideEng
Aug 4, 2009 11:44 AM
DarksideEng
Jul 13, 2009 12:37 PM
