best transmission oil for evo 9??
Old Nov 9, 2016 | 04:43 AM
eddy5201314's Avatar
I'm planing on getting my transmission flush and replace with some good quality oil, hopefully it can improve shifting because I'm getting grinding when shifting from 1st to 2nd when the engine is cold. it's a 2005 evo 9 JDM six speed gearbox, I just need some advice on what is the best oil to use for the transmission?
Also do I need to replace the transfer case and rear diff, ayc oil at the same time? If so do they use different oil?
Old Nov 9, 2016 | 10:47 AM
astral's Avatar
Honestly you really didn't need to create a whole separate thread for the same issue. I already recommended you a fluid mix to use, as did others in your thread. I've replied further in your thread.
EvoAznBoi
49
Apr 16, 2013 06:29 AM
Shirish Agarwal
Mar 27, 2013 06:37 AM
TURBO_S2K
36
Oct 22, 2012 01:14 PM
evoturbo131
Aug 7, 2003 03:33 PM
