Best Transmission and Diffrential Oil
Old Oct 3, 2012 | 01:50 PM
TURBO_S2K's Avatar
Which oils should I use with the transmission and diff?
I heard if I use wrong oil, the shift feel would not be as soft and could damage the transmission
Which oils should I use??
Old Oct 3, 2012 | 02:18 PM
apagan01's Avatar
Many folks here in this forum and outside of this forum as well using with great results these fluids.
Old Oct 3, 2012 | 02:33 PM
ILuvJDM's Avatar
only use Diaqueen in the TC and rear diff
Old Oct 3, 2012 | 02:52 PM
mdost03's Avatar
I just replaced my transmission, differential, and transfer case fluids last weekend with Redline products. So far, working awesome. Went with the Redline "Cocktail" in the transmission and definitely feel a difference with shifting, a lot smoother and less notchy.
Old Oct 3, 2012 | 03:34 PM
Topher86's Avatar
Diaqueen only
Old Oct 3, 2012 | 03:42 PM
mdost03's Avatar
So if I am using Redline fluids, how long should it be before my transfer case goes out because I didn't use Diaqueen? I always read people say to only use Diaqueen, but I know plenty of people who use the redline fluids for years with no ill-effects.
Old Oct 3, 2012 | 03:43 PM
masonh's Avatar
Mitsubishi factory MR trans oil,Motul 300Gear,Redline MT90 or the Redline cocktail for transmission.i wouldn't deviate from these.
for the t-case on basically stock cars use the Diaqueen,but for high hp cars or cars with hardened ring+pinion like on the Jack,Shep or Tre staged rebuilds use the Redline Shockproof just like they recommend.
for the rear use Diaqueen or Redline Shockproof.
Old Oct 3, 2012 | 03:46 PM
Ryan.Kauz's Avatar
I take my information from TRE. I figure John has more experience with Evo transmissions and building them than the commenters here. (no offence guys/gals)
http://www.teamrip.com/manual_transm...tion_info.html
http://www.teamrip.com/transfer_case...tion_info.html
http://www.teamrip.com/rear_axle_hyp...tion_info.html
Old Oct 3, 2012 | 04:40 PM
PatricksEvilEvo's Avatar
I switched to Severe Gear and regret it. Now I have a leak and shift grinds. I don't think it's the fluid being bad but the switch of fluids suddenly after 50k miles. I'm sticking to Diaqueen from here on out.
Old Oct 3, 2012 | 04:42 PM
nytalonTSi's Avatar
Same here!
MT-90 in transmission
Diaqueen in Transfer case
Redline in rear diff most recently
Old Oct 3, 2012 | 04:48 PM
toodrunk2see's Avatar
The guys at jacks trans told me the red cocktail was on the border of friction modifiers and recommended the oem fluid for the trans. For transfer case and rear just like masonh said diaqueen or redline heavyweight shockproof depending on power output.
Old Oct 3, 2012 | 04:49 PM
siemens03's Avatar
I used royal purple on a count it was the only oil i could get next day to make the races and it never gave me any issues. Was a shep tranny and exedy twin.
Old Oct 3, 2012 | 04:50 PM
bigben's Avatar
Diaqueen all around. I've used AMSOIL, and to me their mtg just doesn't shift as smooth. I've also tried the redline cocktail and it felt no different than the mtg.
Old Oct 3, 2012 | 06:05 PM
Jacks actually warns against using royal purple on there website. You might want to check with sheps about that.
Old Oct 3, 2012 | 06:19 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Tranny and diff I use Redline
Transfer case is Daiqueen, anything else will burn it up
Motor oil is AMSOIL
