Enkei RPF1 wheels fitment issue
Old Nov 16, 2016 | 06:16 PM
Im still bothered by the +10 offset. This assembly sticks out a whopping 1.60" from stock
Old Nov 16, 2016 | 07:48 PM
kaj's Avatar
kaj
OP seems okay with it. Stock is super conservative, so it's not as dramatic as it sounds., anyway.
It looks fine.
Old Nov 16, 2016 | 08:11 PM
eddy5201314's Avatar
It looks fine.
Hopefully it will work. and yes: that's how you do it. Just don't OVER heat. there is metal in a few plaes behind the liner.. so you will only be able to move it "so much".
ok thanks but won't it push it back up when the liner is cold? I only need few mm clearance as only rubs when full lock on passenger side.
Old Nov 16, 2016 | 08:13 PM
And it's only rubbing the back part of the liner, the front part have lots of clearance
Old Nov 16, 2016 | 08:16 PM
kyoo's Avatar
you can use an offset bushing (perrin, whiteline, superpro) to move the wheel forward a bit
Old Nov 16, 2016 | 08:48 PM
is it the caster bushing kit? Can I just do a wheel alignment and ask them to set it up? Because I haven't do wheel alignment yet, will it solve the problem if I do a proper wheel alignment and set everything right?(camber, caster) I see other people in this forum using the same set up wheels with no rubbing liner issue. Don't know why mine car rubs
Old Nov 16, 2016 | 09:44 PM
kaj's Avatar
kaj
I have a PSRS and now my tires absolutely destroy my liners. The front of them are almost gone. Made it worse. That is with caster added at the top. It wasn't near as bad before.
If you don't hold it in place while it cools, maybe.
kaj's Avatar
kaj
They all rub.
Old Nov 16, 2016 | 11:22 PM
They all rub.
okay thanks, so what wheel spec is prefect for evo 9? I don't want any spacers, or fender mods but I still want the flush look.
Old Nov 17, 2016 | 07:47 AM
kaj's Avatar
kaj
Wheel design is a factor, that's why your rpf needs a spacer. That makes it hard to say a certain spec will or will not fit.
MODDICTION
EvoX 'For Sale' Wheels / Tires
95
Apr 26, 2018 06:50 AM
XTR Performance
Evo 'For Sale' Wheels / Tires
43
Mar 7, 2013 06:13 PM
Turbotech
21
May 21, 2011 08:42 AM
SOLO2M3
Jan 4, 2008 05:57 PM
IMR-TIM
Jan 31, 2006 04:50 AM
