Timing belt rubbing/making a sound after changing it.
Old Nov 22, 2016 | 03:09 PM
Evo47's Avatar
So I changed my timing belt a few days ago, it did take a while but I did everything correctly and it fired right up. all timing marks are in place, everything torqued to specs. I drove it around and noticed my serpentine belt was rubbing against the timing cover, it was a bit loose. so I fixed it and right after that I got a new sound. It's sort of a ticking/vibrating sound. took off all the timing covers again to check timing and everything is in order. I did however notice that the timing belt is shifted left towards the engine itself. I moved it back towards the outside on the pulleys, cam gears and crank gear. it sounds better for a short while but then it slides back towards the engine. I'm assuming that's the culprit but I could be wrong. how do I keep the timing belt from sliding back?
Old Nov 22, 2016 | 03:55 PM
4b11slayer's Avatar
I think the crank shaft reluctor wheel keeps the belt in place.
Old Nov 22, 2016 | 05:20 PM
Evo47's Avatar
The reluctor wheel is the metal wheel that works with the crank positioning senor right? After I moved the belt and started the car the timing belt slides back and basically rubs against that wheel. if I shine a light between it and the timing belt no light comes through the crack.
Old Nov 22, 2016 | 09:29 PM
4b11slayer's Avatar
Yes the the plate is for the crank sensor. Please post a picture.
Old Nov 23, 2016 | 05:00 AM
Evo47's Avatar
The crankshaft was a bit harder to take a picture of so i took this. Notice how its shifted right
Old Nov 23, 2016 | 08:09 AM
4b11slayer's Avatar
What is shifted right
Old Nov 23, 2016 | 11:22 AM
silverevo05's Avatar
His belt, it's not flush to the left
Old Nov 23, 2016 | 11:40 AM
4b11slayer's Avatar
Ohhhh i see now. Is the reluctor wheel on?
Old Nov 23, 2016 | 12:12 PM
Evo47's Avatar
Heres the belt on the camshaft sprockets. You can tell where the old belt sat, this one just doesnt wanna stay in that position.
Old Nov 23, 2016 | 12:13 PM
Evo47's Avatar
Of course. everything that I took off I put back on.
Old Nov 23, 2016 | 01:27 PM
4b11slayer's Avatar
Sorry stupid question, the car wouldnt have even started. Any way.
The belt on top doesnt look too far back. Does it have rubbing marks?
Maybe the old belt was wider? And the reluctor wheel cant be upside down cause it wouldnt start i think.
Maybe if you add a little more tension?
Old Dec 10, 2016 | 12:58 PM
Evo47's Avatar
Issue is still here. Retensioned the belt and the pulleys. Anyone have any ideas?
Old Dec 10, 2016 | 01:10 PM
barneyb's Avatar
Its a perfect fit on the oil pump sprocket but not on the crank sprocket. Something has changed there.
Old Dec 10, 2016 | 01:14 PM
Evo47's Avatar
​​​​​That issue kinda fixed itself. It's perfectly center on all the sprockets and pulleys now. But I'm still getting a ticking sound.
Old Dec 10, 2016 | 04:58 PM
Same,I've had this for a while now after the timing belt change. Mine is a non rhythmic tick with a sort of scrubbing noise. Never got it to go away though
