⛔★ Clunk or thump when getting on the clutch, bushing?
Old Nov 28, 2016 | 07:31 PM
4b11slayer's Avatar
Diff bushings are super easy since they are on a bracket that is easily removable. The mustache bar requires a deeper part removal.
Old Nov 28, 2016 | 08:40 PM
supak1111's Avatar
So no way to remove the mustache bar or replace the bushing on it without dropping the whole rear diff?
Old Nov 28, 2016 | 08:44 PM
kaj's Avatar
kaj
Originally Posted by supak1111
Oh damn so doing the mustache bushing is quite a bit of work than. Diff bushings seem easy enough.
Much. Remove one side, swap bushing, install, do other side. Boom
Old Nov 28, 2016 | 08:46 PM
kaj's Avatar
kaj
I remember the subframe being in the way. I still have the bushings in the garage LOL
Old Nov 28, 2016 | 09:49 PM
supak1111's Avatar
I'm sure you'll get to it one day lol. We have **** weather here now so I might have to way till spring to do the diff bushings and see if its any better
Old Nov 29, 2016 | 01:19 PM
nor11384's Avatar
FCOTM Winner
I just held the diff in place with a jack and pulled mustache bar off...worked like a charm...
Old Nov 29, 2016 | 01:41 PM
supak1111's Avatar
So you took the mustache bar out without taking anything else out? Or no?
Old Nov 29, 2016 | 03:36 PM
kaj's Avatar
kaj
That is interesting. I could swear I couldn't get the mustache bar to come out with the small space between the body and subframe. Maybe I just didn't try hard enough LOL
Old Nov 29, 2016 | 03:48 PM
nor11384's Avatar
FCOTM Winner
When I did it I replaced diff and mustache bar bushings...it's been a while since I did it so don't remember specifics but I know for a fact I held the diff with a jack while I pulled everything off...axles still in I pulled the mounts and lowered the diff enough to get mustache bar off...use a press to push out bushings...it'll will save you a lot of time...
Old Nov 29, 2016 | 06:01 PM
nor11384's Avatar
FCOTM Winner
Welcome dude ...let us know the outcome
Old Nov 29, 2016 | 06:24 PM
supak1111's Avatar
Sure will. I really wanna know if mustache bar or diff bushings cause the noise. Or both
Old Nov 29, 2016 | 06:27 PM
kaj's Avatar
kaj
But the mustache bar isn't held in by the diff. it's trapped on either end by the subframe. Check AMS's instructions. I have no idea how you did it.
https://www.amsperformance.com/attac...ache%20Bar.pdf
Old Nov 29, 2016 | 06:40 PM
nor11384's Avatar
FCOTM Winner
It's been a long time...maybe i unbolted the subframe? I know for a fact the only thing I removed from the car was mustache bar and mounts...I have to get under there and see what everything looks like again...i know it was pretty self explanatory...I didn't look at any instructions just got under there and used common sense...just have to get under there and do it...
Old Nov 29, 2016 | 06:52 PM
supak1111's Avatar
Too much work if you ask me. I think i'm just gonna do the diff bushings
Old Nov 29, 2016 | 09:43 PM
kaj's Avatar
kaj
It's extremely straight forward which is why I'm so baffled on how to do it with the subframe in place.
