Do I need to upgraded fuel pump for a dyno tune?
because I saw someone saying if I run a open dump pipe on stock turbo will have no boost controller, saw someone saying will help turbo breath lot better to gain more hp. so is it true?
The dump has nothing to do with the boost controller.
anyone knows if I have to removed the A/C compressor to install the MAP o2 dump pipe? Because I can see there not much clearance there, also I have aftermarket intercooler, will that be any clearance issue for fitting a MAP o2 dump pipe?
also the MAP o2 dump won't fit without remove the a/c compressor on my JDM evo9, but I did research lots of people in US running the o2 dump pipe without any modification, is the a/c compressor different position between the USDM and JDM model? someone pls give me a tips how to fit it without removing the a/c compressor?
MisUnderStood
Dec 16, 2015 08:53 AM
QwikEVO
Oct 12, 2014 10:14 PM
Carloverx
14
Dec 22, 2011 01:00 PM
BushBurninEvo
Turbotrix Racing - Edison, NJ
Oct 5, 2004 06:12 PM
what about the a/c line, heard someone have to bent it a bit for more clearance?? I'm running stock header and stock radiator
