replica Voltex widebody kit
I'll post everything here when we get on with it. Currently we just unwrapped a few pieces to look at it. Everything was packed really well and the body guy said it's almost identical in quality to voltex and he can't tell the difference.
Wouldn't touch extreme dimensions/duraflex.. There kits are poor fitting and just bad. VIS still needs work but a better route. Been working at a custom bodyshop for quite sometime and we get ED/duraflex all the time and not once in the 3 years has there FRP stuff fit even close.
17x10 +38, stock body except rolled rear fenders. 20mm front spacer, 3mm rear spacer. Custom trailing arms.
You should be looking at no smaller than a low offset 10.5 wide wheel if you're going wide body.
Making it fit isn't a issue. We get referred by ED. Its just your paying upwards about 200-300 to modify/refiberglass/block sand/fit each part. After the modifications it's gonna fit like a glove.
FINALLY got to start putting this together. My shop has moved so slow but it is what it is. Looks like a bit of massaging and this will be ok. In the photos, its not currently mounted to the car, just ziptied up on the core support and balanced underneath with some stands to keep the bottom from touching the ground.
FRP anything is just a pain in the **** and certainly not meant for a race car. They just have no structure and aren't made in a way that prevents crap propagation like a fiberglass mat would. I have some voltex knockoff rear I thought I would try but I was reminded why that material sucks so much when it arrived. Its now just in the way, but soon to get dumped in the trash unless someone local wants them.
