Evo 8 newbie
Old Jan 23, 2017 | 03:52 AM
Rogueevo8's Avatar
Evo 8 newbie
Alight I got a 05 evo 8 with a leaning out problem
and the mods I got are a MBC and upper ic pipe and lower my psi is at 19-22 don't really know haven't tuned my car and running stock plugs from Autozone and also stock coils don't know why my car is leaning out FYI my afr gauge suck it's eBay.
Old Jan 23, 2017 | 06:05 AM
Fast_Freddie's Avatar
Veteran: Navy
I understand you are probably typing this from your phone, but your question is almost unreadable as the grammar is horrid and jumbled together...
If you have a ****ty ebay gauge then how can you be sure you are running lean?
Old Jan 23, 2017 | 07:16 AM
4b11slayer's Avatar
Get it tuned.
Old Jan 23, 2017 | 08:45 AM
Rogueevo8's Avatar
Yes sorry for the grammar and I am typing from my phone.
well long story short my gauges work fine there not the best quality gauges.
Old Jan 23, 2017 | 08:47 AM
Rogueevo8's Avatar
My car was running rich with the plus I have been using then out of the blue my car just started to run lean idk why.
Old Jan 23, 2017 | 12:03 PM
4b11slayer's Avatar
Maybe your wideband is on its way out..
Old Jan 23, 2017 | 03:14 PM
DeeEvo's Avatar
Get a tune for sure as stated above, use high quality gauges.
Old Feb 8, 2017 | 01:49 AM
GEP's Avatar
GEP
check or replace fuel pump and get it tuned
Old Feb 8, 2017 | 07:28 AM
llDemonll's Avatar
why are you running and MBC if you're not tuned? chances are you probably cranked it up and that's why the car is running lean
Old Feb 8, 2017 | 08:05 PM
jzell97's Avatar
Could be a vacuum line that disconnected on the intake manifold, check around it to see if theres any unconnected lines...that caused my car to run lean under boost
KStyle
Oct 26, 2012 11:34 AM
Crippler
Feb 12, 2011 07:54 PM
NivenHuH
18
Oct 26, 2007 01:55 AM
roadevo
16
May 27, 2007 05:49 AM
awdrift
Sep 21, 2002 04:54 AM
