crank voltage?
Old Apr 2, 2017 | 11:41 AM
nor11384's Avatar
FCOTM Winner
crank voltage?
So the car sometimes does stupid **** while cranking. Sometimes it'll start cranking and halfway will stop cranking and make a weird noise. When this happens the gauges (speedo, rpm, etc go up and down as if to reset). I just let off the key and crank it again and it'll start no problem. Sometimes it'll start right away. I took it to advance to check battery, alt, and starter. They said battery and alternator was good but the voltage drops while cranking and it's probably the starter solenoid. Now, while ago I broke the stud on my original solenoid so I took it to a shop that does starters and alternators and they replaced it with one that they said would work. What do you guys think? Can it be the solenoid?
Old Apr 2, 2017 | 03:49 PM
barneyb's Avatar
Check out the heavy cable from battery to starter for tight clean connections. Also make sure the small wire at the starter is on firmly. People complain that this wire keeps falling off but it only happens once the connector is broken.
Old Apr 2, 2017 | 03:52 PM
nor11384's Avatar
FCOTM Winner
I got the car with the battery relocated to the trunk...maybe it is a good time to take it apart and make sure the did the job correctly...I will check the starter cable too...
Evil Colt
Jan 27, 2016 09:52 AM
heyythurr
Nov 3, 2014 11:52 AM
_des_
Mar 8, 2012 07:56 PM
hybrids14
Mar 19, 2007 01:06 PM
ct9a gsr
14
Jul 1, 2005 07:40 AM
