fuel problem issues
Old Apr 10, 2017 | 10:58 PM
Evoguy!123's Avatar
fuel problem issues
okay so i have a problem putting fuel in my evo, My car runs good and all but when i go low on fuel and fill it back up my car starts to misfire alot and wants to stall on me, what could it be? also gets a code P0090 fuel pressure soleniod but been replaced and wire are good.
Old Apr 19, 2017 | 11:47 AM
supak1111's Avatar
I'll jut put this out there because I've see it happen but you could have water in your gas tank.
Next time you are almost out of gas, take off one fuel line from the engine (supply line) extended some if you have to, put it in a bucket and go put the key in the ON position like 20 30 times till you empty little gas you have in the tank. If no water comes out with the gas you can probably stop
Old Apr 19, 2017 | 01:41 PM
4G63_EVO's Avatar
Not a bad plan
Old Apr 19, 2017 | 01:42 PM
RightSaid fred's Avatar
Water is heavier than fuel.
It's at the bottom.
That's why fuel has detergent in it.
So that water and fuel mix.
Same reason that engine oil has detergent in it.
Tw3NTy0n3
Feb 17, 2017 08:57 PM
maknuge
AEM EMS
11
Nov 19, 2014 11:11 AM
phenem
Oct 11, 2008 08:47 PM
Scud!
May 16, 2004 04:42 AM
