Issue with cylinders cutting out or something? Tuner and I are stumped.
Old Apr 18, 2017 | 01:13 PM
Bmurray's Avatar
Originally Posted by DecBro
When it bogs down is it usually when you shift under WOT, then back to WOT? Curious as I've had that same problem appear a couple times.
Do you run a test pipe or do you have a cat installed? What PSI you running? I may have missed it.
Yes happens after wot then back to wot, I always lift when shifting. Test pipe. 28psi FP red.
Old Apr 18, 2017 | 01:25 PM
LetsGetThisDone's Avatar
I thought you were running speed density? How was there a stock MAP sensor on it?
Old Apr 18, 2017 | 01:59 PM
Bmurray's Avatar
the car was just switched to speed density this past Wednesday.
Old Apr 18, 2017 | 02:30 PM
Swap another Omni MAP sensor on. It sounds like a fueling problem caused by improper airflow calcs which would be caused by a bad MAP. Omni doesn't exactly have a 100% track record like an OEM part. I just replaced on last week that was reading 2-3psi high (comparing load vs boost), and would occasionally cause the car to hiccup just like you're describing yours is.
Old Apr 18, 2017 | 04:36 PM
Bmurray's Avatar
It happened with the original oem (54k mile) sensor as well. But worth a try
Old Apr 19, 2017 | 07:02 AM
Ians06's Avatar
MAP sensor!
Old Apr 19, 2017 | 07:55 AM
You can't run SD on a stock MAP. It sounds like there is an airflow calc issue. On SD, the MAP and RPM are the only inputs for that.
Old Apr 19, 2017 | 08:22 AM
Bmurray's Avatar
I know that. The issue happened with the oem map sensor on MAF. I switched the car to speed density last wednesday with the new Omni 4 bar and problem is still happening. Hopefully that clarifies a little. I do not believe it is the map sensor. Unless it's a freakish coincidence that the original map sensor happened to be messed up AND the new Omni 4 bar is messed up. Just don't think so.
Old Apr 19, 2017 | 09:16 AM
4G63_EVO's Avatar
Ive seen freakish stuff happen before, you never know
Old Apr 19, 2017 | 09:17 AM
When running the MAF the stock MAP sensor doesn't really do anything except act as input for the ECU to calculate when to use the EGR.
Old Apr 26, 2017 | 06:09 PM
Bmurray's Avatar
Here are the overdue pictures of the plugs.
Old Apr 27, 2017 | 12:04 PM
Why are the electrodes bent on two of them? That could be an issue, causing a misfire. Get new plugs. Gap them to .020" with a FEELER GAUGE, not the plug gapper thing from autozone.
Old Apr 27, 2017 | 01:01 PM
4G63_EVO's Avatar
Good eye
Old Apr 27, 2017 | 07:32 PM
Bmurray's Avatar
Def a good eye. New plugs will be picked up tomorrow. Currently awaiting a new intake from ETS and then will report back
Old May 8, 2017 | 09:32 AM
DecBro's Avatar
Any update on how the new plugs went? Let us know, I'm keen to see what fixes the issue as I've had the same thing happen a few times. I'm gapped at .23 on OEM plugs, but might regap to .20
