Timing question, need help
Old May 7, 2017 | 12:38 AM
Heirthos's Avatar
So I just did a cam install, and I had my cam marks line up with my valve cover once, then many rotations later I have not gotten them to line up like that. They get close, but both marks on the cam gears are just slightly away from the valve cover marks. Is this OK? Or is my timing messed up? Belt was not moved and no teath were jumped, just the marks don't line up. Not sure if this is OK or not. I did start it once, had to give it gas and it idled for about 30 seconds then died. Obviously I know it won't run correctly without a tune but I didn't think it would turn off.
Old May 7, 2017 | 10:47 AM
4G63_EVO's Avatar
in for the answer
Old May 7, 2017 | 11:15 AM
butte's Avatar
Need a little more information. How far off is 'slightly away from the marks'?
Every time I've done the timing on my evo the indicators will be about a milometer or two off of the marks because of belt tension. But if you're off by the length of one tooth then you've got a problem.
Have you check to see if the other gears are on the marks? Crankshaft, balance shaft, oil pump?
Old May 7, 2017 | 12:09 PM
Heirthos's Avatar
This is how they currently are:
https://gyazo.com/0127052c459382048ba4fb1556badd97
So by what you said I'm assuming I have to fix this?
Old May 7, 2017 | 06:31 PM
4G63_EVO's Avatar
Im no expert but that looks way off to me
Old May 9, 2017 | 11:37 AM
butte's Avatar
Yeah, the intake sprocket is off by two teeth. I don't know how far you need to be off to start bending valves but that's definitely a problem as it is.
Did you check the other sprockets below as well?
Old May 9, 2017 | 11:56 AM
Heirthos's Avatar
I have to take off the serpentine belt to do that correct? I redid the cams and the marks line up correctly now even through many rotations. Is it possible that the timing could still be off though? I really don't want to take off the serpentine belt for this but I guess it's better than buying a new motor.
Old May 9, 2017 | 12:09 PM
4G63_EVO's Avatar
Yes its possible, check the timing on your other sprockets
Old May 9, 2017 | 08:06 PM
barneyb's Avatar
The place the belt is most likely to jump is at the crank. On several occasions, when adjusting the belt tension, I heard "bonk" and looked over to find the belt at the crank had jumped a tooth. If the cam and crank marks are on then all is good.
Old May 9, 2017 | 09:46 PM
Heirthos's Avatar
And to check the crank I need to take off the serpentine belt, and a few other things right?
Old May 9, 2017 | 10:03 PM
barneyb's Avatar
Yeah, you'd be diving deeper than the serpentine belt: engine side cover, serpentine belt tensioner, water pump pulley, serpentine belt idler, upper timing cover, crank bolt and pulley, motor mount and lower timing belt cover. Download the FSM and read the timing belt section if wanting to do this.
Old May 10, 2017 | 03:12 AM
Heirthos's Avatar
So I think I fixed it, does this look good?
Old May 10, 2017 | 05:53 PM
barneyb's Avatar
Yes it does! A novel way of removing the timing cover too.
Old May 10, 2017 | 07:52 PM
Heirthos's Avatar
Yeah haha I was trying to cheat taking off everything and it snapped. It still bolts on and seals enough so eh oh well
Old May 14, 2017 | 10:47 AM
kennydsmevo's Avatar
Looks right now. Usually what throws it off is messing up the crank sprocket. Yu need to turn crank back 1/2 tooth and as you adjust the pulley,the crank lines up to the mark
oneofakindracer
Nov 23, 2010 04:51 PM
4mypsp
Nov 9, 2010 11:51 AM
Paintballer81
Apr 1, 2010 12:40 PM
superman105
Mar 11, 2005 05:36 PM
