Oil pump seal
Old May 22, 2017 | 01:31 PM
benIX's Avatar
Oil pump seal
Hi fellow evo owners,
I am really wishing someone can help me out here. I just built a long rod 2.4 with mivec head. i have a oil leak from behind the oil pump sprocket. what is weird to me is that the front case/ oil pump is brand new OEM pump. any ideal why it would leak? could the seal be bad from the manufacture? I will take the timing belt and the oil pump sprocket off to see whats causing the oil lean. the whole built including the oil pump have 140 miles. its not a really bad leak but its a leak and its annoying. one last question i deleted my balance shafts how would i be able to take the sprocket off? i have an impact gun but wouldn't it just turn with it if there is no resistant on it? sorry if i am reviving an old subject/Threat but i couldn't find anything that relates to my issue as far as mileage and everything being brand new. Thanks in advance.
Old May 23, 2017 | 10:37 AM
bolothedv's Avatar
never changed this out, but I was looking at the procedure and I don't see a seal behind the oil pump sprocket. Sure it's not leaking from the timing chain cover seal?
Old May 23, 2017 | 12:50 PM
benIX's Avatar
yes there is a seal behind the sprocket which the sprocket goes in to seal it. if you look at evo front case and see the oil pump shaft you will see the burgundy color seal in there. and i have a evo 9
Old May 23, 2017 | 01:15 PM
LetsGetThisDone's Avatar
Who knows how long that oil pump sat on the shelf before you got it. Very possible for the seal to have gone bad.
Old May 23, 2017 | 03:14 PM
benIX's Avatar
Ya that's true. I ordered a new seal and a new oil pump sprocket hopefully that will fix the leak
EvoIIIAj
Jul 18, 2013 06:42 PM
My03evo
May 10, 2013 06:44 AM
yellowevo82
Jan 6, 2009 02:33 PM
DG Motors
17
Jun 30, 2008 08:55 AM
