Double pumper install question
Hey everyone, so I'm installing my TSComptuned double pumper, and I have my battery relocated into the trunk. Everything is in and ready to go, except the vacuum line that needs to be connected. Since my battery is in the trunk, at least to my knowledge, there aren't any vacuum lines near the battery as it sits. So my questions is, where does everyone with a double pumper and trunk relocated battery run the vacuum line? I was trying to avoid running a vacuum line through to the engine bay if possible, but if not no big deal. I figured I may just be overlooking something stupid simple, and I've tried searching and couldn't find what I need specifically so if anyone could help i'd really appreciate it.
The 9psi switch line to activate the second pump? Place the sensor in the engine bay and route a wire from that sensor to the relay/pump area. There is no need bring a vacuum line into the trunk as it can bend and pinch itself shut along the way.
Got it figured out. I just made a dumb mistake... What I get for working on my car with the flu. Thanks for the reply.
STIbyebye
Apr 28, 2016 05:12 PM
sspaladin28
Jan 23, 2011 09:16 PM
MR.06MR
Jun 30, 2009 02:32 PM
Nesiop
Aug 4, 2007 08:44 AM
