No Oil Pressure Below 3k RPM
Recently I noticed a small oil leak at the track. Noticed that the underside was all wet with fresh oil around the filter area. I think it was a loose oil cooler line.
At the same time I noticed that oil pressure was reading 0 below 3000 rpm, after which it would jump up to around 75. It's a newer gauge and sending unit, both of which were working just fine before the leak.
Anybody have any ideas?
There's really only one thing you can do, and that's verify that you do in fact have an oil pressure issue. Buy an oil pressure test kit. I've had this happen three times in the past four years and it's always been a faulty oil pressure sending unit, though your circumstances are a bit different.
If you mounted the oil pressure sensor directly to the oil filter housing, you likely wiped out the sensor. You need to get a remote mount line like the one STM sells.
http://streettunedmotorsports.com/pa...er_housing.htm
Also that remote line can rub on the axle, it's better than mounting it directly but it still takes a bit of fiddling to put it somewhere that makes sense. I gotta get back in there and rotate it.
AC line bracket, ziptie, Power Steering Hose, ziptie to ziptie to ziptie to Oil Pressure Sensor
this **** is wack
also power steering hose was rubbing on timing belt because of the Radium catch can, so I had to put the upper timing cover back on even though it no longer fits because of the 4G64 block, in case you're wondering
Inprogress
May 15, 2014 06:43 AM
Inprogress
May 15, 2014 06:42 AM
hiboost2.0
16
Jan 2, 2014 08:10 AM
cij911
11
Nov 14, 2011 08:18 AM
jbigelow
14
May 3, 2005 08:46 AM
