Evo 8 4G63 Block, why it is different?
Old Jul 27, 2017, 10:15 AM
maxroach's Avatar
Hello guys.
I have here 4G63 block that I was told that it was from Evo 8.
but how come my evo 8 water pump is not covering the cavity of coolant passage?
please tell what 4g63 block I have.
im assuming its from 2003 4g63T jdm outlander, or jdm evo 8 block?
but not positive.
Thanks
This is the original pump
With new water pump. See the exposed cavity?
Old Jul 27, 2017, 11:05 AM
GSX_TO_EVO's Avatar
It's an Evo 4 block.
Old Jul 27, 2017, 05:03 PM
Ferp's Avatar
Handy thread here: http://www.evoowners.co.uk/threads/mitsubishi-lancer-evolution-engine-codes.2401/
You got the worst bottom end of all the rotated 4G63s.
Old Jul 27, 2017, 06:12 PM
4G63_EVO's Avatar
Originally Posted by Ferp
Handy thread here: http://www.evoowners.co.uk/threads/m...ne-codes.2401/
wow, that F***** sucks
Old Jul 27, 2017, 06:32 PM
maxroach's Avatar
And Why is that?
Old Jul 27, 2017, 07:05 PM
gsrboi80's Avatar
Prone to crank walk, ring, piston issues that were said to be sorted in the Evo V and up.
Old Jul 27, 2017, 07:30 PM
maxroach's Avatar
Even with fully built?
Forged rods H manley
Wiseco Pistons
Acl bearings
Evo 8 crank
Old Jul 27, 2017, 08:08 PM
Ferp's Avatar
Other than the prone to crank walk thing the rest is bogus as far as I'm aware. I've had 4 blocks apart side by side to a 5, 6, and 8 blocks and have seen no difference in regards to pistons etc. I believe the part numbers were even the same.
Old Jul 29, 2017, 01:03 AM
TariqEvo's Avatar
Originally Posted by maxroach
Hello guys.
but not positive.
Thanks
an 8 block would have a balance shaft belt area near the crank pulley
Old Jan 10, 2018, 04:33 PM
LJ7two4's Avatar
Can one simply use an evo 8 block and evo 4 head? I was planning on building my evo 4 and wanted to just use and evo 8 block....
Other option would be to use an entire evo 8 motor....but would the evo 8 motor bolt up to my evo 4 transmission and tcase?
Old Jan 11, 2018, 03:55 PM
Teal2nnr's Avatar
Nevermind.
CeliOnce
19
Jun 25, 2015 07:48 AM
Phoenix*
Dec 12, 2011 08:23 PM
Girodisc Martin
Mar 7, 2007 09:50 PM
Ralli04Art
Dec 15, 2005 06:24 AM
scottsee
Mar 27, 2005 07:42 AM
Quick Reply: Evo 8 4G63 Block, why it is different?
