Temperature gauge all the way to hot
Old Aug 16, 2017 | 03:10 AM
Kode's Avatar
Originally Posted by hutch959
oh yea... this^^^
your ground to the intake manifold , if left off, will mess with your temp gauge reading.
Ground is intact
Old Aug 16, 2017 | 09:05 AM
barneyb's Avatar
Do the fuel and temperature gauges act up at the same time?
Old Aug 16, 2017 | 10:18 AM
Eric SlowEvo8's Avatar
all other grounds also good and tight?
Old Aug 17, 2017 | 04:01 AM
Project_Broke's Avatar
Originally Posted by Kode
Replaced the sensor, and has nothing changed temp gauge still go up. Try to unplug the connector and the gauge slowly going down. Same when plug in it will going up.
Sounds like a resistance issue.
Check the wire as others have said.
Old Aug 17, 2017 | 06:45 AM
4b11slayer's Avatar
You can also overlay the wires from cluster to engine bay for testing. Run your own wires see if it fixes.
Do you know how to use a meter? Test resistance in the wires from component to component. Also check continuity from wire to wire to emsure they arent touching. Then check continuity from each wire to ground to ensure no short is present.
SavageEvo9mr
Apr 24, 2017 06:00 PM
Brian Chen
Northwest Region
Jun 13, 2003 04:47 AM
