New Issue Came Up Today - Starting issue
Old Aug 14, 2017 | 07:04 PM
Kraise's Avatar
Hey guys,
New issue today, car was running fine a week ago, tried to start her up today and this is what happened,
Car cranks and turns on but idles low at around 950-1000 for a minute or two, shuts off and then doesn't start up; the car cranks and small pop but doesn't turn on at that point I stop cranking; if I give the car gas it will turn on but have to hold the gas for it to hold idle if i let go it will turn off
Lastly, after a 5 minute break of frustration, I crank the car and it will start for a minute and then shut off again and repeat with the same issue.
**Did not experience this issue last week and the car came home and parked fine
Relevant mods:
2.3 Stroker, 6466 gen 2, STM Triple Pumper, AEM Infinity, AEM Flex Fuel Sensor, Bosch 2200 CC Injectors, Brand new battery.
Old Aug 14, 2017 | 10:16 PM
4b11slayer's Avatar
Fuel pressure.
Codes
Tps
Map
Old Aug 16, 2017 | 03:46 PM
Kraise's Avatar
Today started the car up and it started right up idled with vacuum and warmed up quickly, as soon as I closed the hood the car read 0 vacuum and slowly shut off, usually get 0-6 vacuum on start and 6-10 on warm, could this be a sensor issue that gets hot resulting in no vacuum?
Old Aug 16, 2017 | 06:42 PM
4b11slayer's Avatar
Does the car have a exhaust on it? Or any huge exhaust leaks?
Old Aug 16, 2017 | 07:51 PM
Kraise's Avatar
I have a bumper exit exhaust which has been on for months, no exhaust leaks, I think it might be the cam sensor I ll check it out tomorrow, Im starting to lean towards a connection issue of some sort, the fuel pumps are also fine
Old Aug 16, 2017 | 07:56 PM
4b11slayer's Avatar
Oh ok i have experienced a similar issue but the car had no exhaust and as soon as o closed hood it would choke its self with all the fumes.
Old Aug 17, 2017 | 06:01 PM
Kraise's Avatar
Narrowed it down to my cam position sensor, I played around with and the car started right up again; the harness just slips right off so I ordered a sensor for peace of mind but I was also looking to replace the harness, do you know where I can get one by any chance?
Old Aug 22, 2017 | 10:47 AM
Project_Broke's Avatar
Maybe I remember wrong, but isn't it part of the entire engine harness?
Best off finding either a pigtail, or a connector and repining it yourself.
Or ziptie that *****, this would be my choice.
Old Aug 22, 2017 | 03:40 PM
Kraise's Avatar
Hey Project Broke, I looked at my sensor and the sensor itself has a broken clip which lets the harness slide off, regardless I ordered a pigtail to have on the side if the connection still sucks
Thanks
masonh
12
Sep 5, 2012 11:06 AM
EvolutionTheory
10
Nov 15, 2009 06:25 AM
EvoVIIIJeremy
May 22, 2008 07:20 PM
4G94lancer420
Lancer Engine Tech
Jan 16, 2003 01:45 PM
