No IC
Old Sep 1, 2017 | 09:52 PM
ghost8's Avatar
Veteran: Navy
No IC
Anyone else see AG's karma with no IC? well if you live under a rock here you go.
I wonder how much of difference this makes in response, an ic could be pretty restrictive in high flow right and if you go larger then its more volume to pressurize. So I think that there could be some gain from this and I'm going to fab some charge piping (because it not ic piping without an ic) and do logs and testing. what do you guys think?
I'll be logging iat and all the normal logs and do some vd before and after
Old Sep 2, 2017 | 12:17 AM
Jp7's Avatar
Jp7
With the right fuel (methanol) no intercooler is needed.
Old Sep 2, 2017 | 01:40 AM
RightSaid fred's Avatar
You just use water injection instead.
It used to be done that way with suck through carburettor / turbo setups.
It's more efficient without the intercooler.
So long as you inject enough water to keep the temps down and also have a good enough ignition to stop it misfiring.
