Blitz-SBC-i-D - EVO TME
Old Nov 13, 2017 | 03:11 PM
rx7rotary's Avatar
Hi guys,
I have just purchased an EVO TME, and it has a Blitz boost controller. The reading on it seems correct in terms of boost and vacuum, but setting a 17psi boost on ch4 doesnt work. It still boosts 20psi. Whatever I do I cannot lower the boost, and this is my goal, to have one channel which is low boost 17psi and then one channel with 20psi.
Any suggestions?
Mark
Old Nov 14, 2017 | 08:32 AM
meka's Avatar
do you have the manual? http://www.mkivsupraownersclub.com/R...D%20manual.pdf
Make sure it's all connected and set up properly as shown.
Check that all your lines are intact and that your wastegate actuator is functioning properly. Is it stock? they can rust and get suck.
Once you've got all that sorted and no boost leaks, switch it to manual mode and set it low. Do some test runs and work your way up on the manual mode until you have the boost you want.
If that doesn't solve it, read up on "overboost" "boost creep" and take a closer look at your actuator and wastegate.
Old Nov 14, 2017 | 08:39 AM
nemsin's Avatar
Or just remove the blitz boost controller and go with a manual boost controller. Might be a good idea to get the car retuned too.
Old Nov 14, 2017 | 09:38 PM
rx7rotary's Avatar
Ok, looks like the actuator I run is a 1.2 bar actuator, so that means that I cannot lower the boost under 1.2 bar. I can only go up. I really wanted to run 1bar, on one channel, 1.2 on ch 2, and 1.4 on ch3. But all good.
Cheers for your help guys.
Narayan
Apr 20, 2011 08:37 AM
clamps
Apr 14, 2008 09:22 PM
pnoiboy626
Jun 12, 2005 07:09 PM
Lars
Sep 20, 2003 12:55 AM
